How should my S3 run at low speed? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 12-04-2012, 08:23 PM   #21 (permalink)
Main Motorcycle: 2011 S3
Originally Posted by bevivino1 View Post
I have a stock 2011, it is smooth as silk in the riding conditions you describe.
Like others have said, sounds like a minor fueling issue.
My 2011 (all stock) is the same as above, smooooooth.
bevivino1 is online now   Reply With Quote
Old 12-05-2012, 01:44 PM   #22 (permalink)
Main Motorcycle: 2011 Speed Triple 1050
Dr.Speed's Avatar
I have a 2011, which is stock performance-wise. It's very smooth as well. Almost too smooth
Dr.Speed is offline   Reply With Quote
Old 12-05-2012, 03:55 PM   #23 (permalink)
Main Motorcycle: 2012 Bonneville Black
Other Motorcycle: 2012 Speed Triple
I have a 2012 Speed that I purchased used with about 2500 miles on it. The first thing I noticed with the slight hesitation/engine vibration from anything below 3k rpms. I thought there was something wrong with the engine, but the tech said the factory map runs lean for emissions purposes.
Once I put the Arrow high mounts on and loaded up the tune with Tunecu, it completely eliminated all hesitation down low and the bike now rides super smooth!
Stripleville is online now   Reply With Quote
Old 12-05-2012, 10:22 PM   #24 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
Did you reset adaptives in the course of loading the new tune?
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 12-06-2012, 02:23 AM   #25 (permalink)
Yes, I did the 10-20 minute idle without touching the throttle until the TPS light turned green
Old 12-06-2012, 07:21 AM   #26 (permalink)
Joe Houle's Avatar
This alon has a big effect on how the bike runs. I would start there.
2001 Speed Triple or 2003 speed four???? TheBigCat Speed Triple Forum 8 04-26-2010 04:31 AM
