Motorcycle.comRacerPartsWholesaleBikeBanditSpringfield ArmoryMotorcycle.com Classifieds!ShopTriumph.comSportbikeTrackGearAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 01-10-2006   #1 (permalink)
On my 2000 S3 I just bought the Triumph tank bag. In the directions it doesn't really show how to mount it for the S3.(correctly). It only shows pictures of Bonniville and Sprint. I have it going under the tube frame right under the ''955i'' logo in the front and in the back the two straps both go under the rear fuel tank mount. Is this how the rest of you did it? The brackets that came with it can't be used on the S3 without trimming the fairing mounts. I wouldn't do that anyway.
AndrewTriumph is offline   Reply With Quote
Old 01-11-2006   #2 (permalink)
Favorite Bike: '01 Speed Triple
What brackets? You have to mount the velcro bottom pad securely, and it sounds like you have the front correct. You have to run the two long straps down the back corners of the tank around the tank mount and cinch them up tight. It helps to get the quick release seat pins from www.rideteamtriumph.com as you have to remove the seat to attach the pad.
Speed3 is offline   Reply With Quote
Old 01-11-2006   #3 (permalink)
Then I do have it on there right. I didn't use the brackets for it would have been impossible anyway. Thanks. :-D
triumph Tank Bag mounting question DrTriumph Sprint Forum 5 03-22-2007 06:27 AM
Tank Bag/Tail Bag for Daytona 675 Xavi Daytona675 Forum 3 03-12-2007 09:06 PM
06 bag mounting alert!!!!!!! hww62 Sprint Forum 1 06-25-2006 09:05 PM
Saddle bag mounting alternatives Gene-O Twins Talk 9 05-05-2006 05:10 PM
bag mounting system schwartzkm Twins Talk 10 01-22-2006 08:43 AM
