Getting a Dyno on a 2011 Triple - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old 11-11-2012, 02:24 AM   #1 (permalink)
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
I have an appointment to get a dyno run on my Triple next Saturday. There is a place in Santa Clara that uses TuneECU specifically for their dyno tuning and the owners are british. They had a few triumphs in their shop too so I feel fairly confident although I didn't see any reviews on yelp for their dyno work. I trust them more than my dealer. The question I have is though, should I map with or without the SAI blocked?
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is online now   Reply With Quote
Old 11-11-2012, 06:34 AM   #2 (permalink)
Main Motorcycle: 2011 WHITE Speed Triple
I vote blocked
2011 Crystal White S3
All the R&G bits/Ceramic Exhaust/Lots of CF bits
Runs Best on REMUS! 20487 Tune (hang on!)
Speedycaptain is online now   Reply With Quote
Old 11-12-2012, 08:20 PM   #3 (permalink)
Main Motorcycle: 2013 Tiger 800 XC
No difference at all bros!
And for all the work you have to do to remove it, let it stock....
David L. is offline   Reply With Quote
Old 11-15-2012, 02:48 AM   #4 (permalink)
Moogs's Avatar
I can plug it in 5 minutes. Thank I'll see how the bike runs with and without first then decide.
Sent from my Nexus 7 using Motorcycle.com Free App
Old 11-15-2012, 03:11 AM   #5 (permalink)
Main Motorcycle: Speed3 -09
Martin_R's Avatar
You need to block SAI to have reliable measurements on the dyno. If SAI is open the fresh air will throw off the exhaust gas analyzer.
You can re-enable SAI after dyno if you so wish.
I would also weld a M18 O2 sensor bung onto the header collector, to improve readings on the dyno.
Martin_R is offline   Reply With Quote
Old 11-15-2012, 02:20 PM   #6 (permalink)
This. You don't get proper readings if you inject air into the exhaust.
Sent from my HTC Glacier using Motorcycle.com Free App
Old 11-15-2012, 02:31 PM   #7 (permalink)
Legend
DEcosse's Avatar
Exactly as Martin says - the dyno operator will probably insist anyway
What is the shop?
There is also FactoryPro in San Rafael or JT&S Performance at Infineon Raceway
Old 11-15-2012, 05:44 PM   #8 (permalink)
Moogs's Avatar
What is the shop?
Hey DEcosse.
Ok. Gonna plug it tonight. The shop was gonna be Evolution in Santa Clara but I don't think they have a lot of experience. Fastline was recommended in Fremont. What do you think?
I still have to sort a high idle problem. Think my open and close cables aren't set right. Lots of play on last nights run after replacing the throttle body assembly.
Old 11-15-2012, 06:02 PM   #9 (permalink)
Legend
DEcosse's Avatar
I doubt if Fastline has even seen a Triumph?
Have no basis for that - just a feeling
Are they using DynoJet?
If so, not ideal for tuning with TuneECU or TuneBoy - most DynoJet operators are not real tuners, they just run the automated programs.
Ask them if they have experience of a Keihin Triumph and understand particularly how to manipulate the L vs F tables.
Either of the places I mentioned are good - I have personally worked with Jim at JT & S on the dyno and he is good guy;
I think FactoryPro might have the most experience.
Check out their velocity stacks! - http://www.factorypro.com/Prod_Pages/prodtd_955.html
Old 11-15-2012, 09:44 PM   #10 (permalink)
Moogs's Avatar
Thanks. I'll go wherever the most experience is with Triumphs. If you say JT&S then I'll give them a ring.
Evolution runs a mustang dyno and uses TuneECU exclusively. They did have a couple triumphs there but I think them having a dyno is new.
Not sure about Fastline yet. Didn't call em but they came recommended on the barf but those were Japanese bike guys.
2011 Speed Triple headlight swap with 2011 Street rt001 Speed Triple Forum 1 03-15-2011 03:24 PM
Speed Triple Dyno Results Arsenal741 Speed Triple Forum 6 08-03-2010 12:01 AM
2011 Ducati Monster vs. 2011 Street Triple R Victusvita Sprint Forum 7 07-06-2010 06:51 PM
2005 Speed Triple on the Dyno TonUp Speed Triple Forum 8 05-21-2007 06:49 PM
TBS with triple cams Dyno run Saigon5 Hinckley Classic Triples 49 04-15-2005 03:45 PM
