Rear hugger mounting bolt size? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-08-2012, 08:05 PM   #1 (permalink)
Newbie
Main Motorcycle: 2007 Speed Triple
Thee Goat's Avatar
Does anybody know the bolt size for the holes in the swing arm for the hugger mounting?
Thee Goat is offline   Reply With Quote
Old 11-08-2012, 08:15 PM   #2 (permalink)
Main Motorcycle: '01 Speed Triple
Try to match a small bolt from somewhere else on the bike. If it fits, match it at the HW store... I think it's an M6x12mm.
Speed3 is offline   Reply With Quote
Old 11-08-2012, 09:17 PM   #3 (permalink)
Lord Flashheart's Avatar
Other Motorcycle: 2006 Speed Triple
I just pulled the LH one off mine - it's M6 x 1.0, 30 long, with a T30 Torx head.
Cheers,
Lord Flashheart is online now   Reply With Quote
Old 11-09-2012, 07:36 AM   #4 (permalink)
Main Motorcycle: 2007 Triumph Speed Triple
Ebster1085's Avatar
I used M6 x 1.0 x 25mm and they worked great!
LSL Damper CRG Mirrors OES Sliders CF Frame Covers CF Heel Plates CF Tank Pad CF Rear Hugger Sunline Shifter LED FE Kit MIVV CF Slip On TuneECU K&N Air Filter FH012AA R/R Stoltec Starter Cables The2Wheels Levers Rick's Hotshot Stator
Ebster1085 is online now   Reply With Quote
Old 11-13-2012, 05:58 PM   #5 (permalink)
Newbie
Thee Goat's Avatar
Smile Thanks!
Thanks gents!
Cheers!
T100 rear fender bolt size canuck_triumph Twins Technical Talk 1 05-21-2012 08:50 AM
Speedy Rear Fender Bolt Size? sharp21 Twins Technical Talk 3 02-21-2009 01:51 PM
rear foot peg bolt size 7mm 1.0?? jfenton Twins Technical Talk 2 08-07-2007 06:50 AM
TOR mounting bolt size? Programr Twins Technical Talk 4 02-26-2007 05:33 PM
05 shock mounting bolt size GBG Twins Talk 0 04-16-2006 02:03 PM
