Intermittent speedo failure - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 2 (permalink) Old 11-07-2012, 11:09 PM Thread Starter
Main Motorcycle: 12' Bonniville SE
Other Motorcycle: 04 Speed Triple
A couple weeks ago I noticed my speedometer had not budged off of zero during my daily commute to work. On the ride home I was relieved to see it working properly again. Happened again a couple days latter. Pulled the front wheel and verified the Speedo drive looked OK. I noticed the issue occurred on nights I elected not to hook up the charger. A check of the battery revealed leakage and corrosion. Bingo.A new lithium Shoai battery has curred the problem. I will report any issues with the Shoai.
threetwoone is offline
post #2 of 2 (permalink) Old 11-07-2012, 11:14 PM
DEcosse's Avatar
If you update the map in the ECM with TuneEcu your problem will be permanently resolved - this was a troublesome 'feature' that was subsequently disabled in later versions of the map
DEcosse is online now
intermittent speedo tucsonjim Sprint Forum 1 01-24-2010 08:39 PM
Speedo intermittent gsp0702 Tiger Workshop (archive) 7 03-23-2009 12:25 AM
Intermittent speedo fault??!!! triple-64 Speed Triple Forum 6 07-08-2008 09:37 PM
Neutral Light Intermittent Failure. Ballacraine Maintenance & Workshop Talk 3 05-18-2007 12:57 AM
01 Adventurer intermittent sprark failure! HELP! micky Maintenance & Workshop Talk 0 03-26-2006 10:42 AM
