Help/Input Needed - 2002 Speed Triple 955i Stumle/Hesitation Below 3k RPM... - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-18-2012, 03:05 AM   #11 (permalink)
Main Motorcycle: 2003 Speed Triple
PhilM's Avatar
I think you'll find that for a 12:1 compression engine 160psi is low.
Have you swapped the ECM's?
PhilM is offline   Reply With Quote
Old 11-18-2012, 03:34 AM   #12 (permalink)
Main Motorcycle: Nada!
inderocker's Avatar
Not at 5,368'... guess I should of mentioned that earlier. ECM swap is next.
inderocker is offline   Reply With Quote
Old 11-18-2012, 12:37 PM   #13 (permalink)
Legend
DEcosse's Avatar
New data!
The baratron is built into the ECM and should accommodate the pressure change - I've had my Daytona up to 10,000 ft and still runs well
There should be a hose from the ECM baratron to the airbox - make sure that hose is not kinked or folded. Doesn't make whole lot of difference if cracked as is really just sensing atmospheric pressure and airbox pressure not significantly different.
So you are obviously 'lean' at the bottom end - which means not enough gas for the volume of air. K&N would actually make situation slightly worse.
Try loading one of the TORS tunes with TuneECU, which will enrich things a bit for you.
Old 11-18-2012, 03:15 PM   #14 (permalink)
inderocker's Avatar
Fixed! It was the ECM. Out of the hundreds of bikes I've owned, both personal and for resale, I've never seen a faulty ECM. On that note the majority of those do not have tunable ECM's... I suppose someone could of half fried this at some point when tuning it.
Old 11-18-2012, 04:58 PM   #15 (permalink)
Legend
DEcosse's Avatar
I would doubt it was the ECM itself - probably has different map in it
Old 11-18-2012, 06:15 PM   #16 (permalink)
inderocker's Avatar
I uploaded the same map, 10157.
Old 11-19-2012, 01:19 AM   #17 (permalink)
Main Motorcycle: t509
Isn't that a concern? A difference greater than 20% is usually a bad sign. But in this case it's probably just a valve adjustment.
12340987 is offline   Reply With Quote
Old 11-19-2012, 04:10 AM   #18 (permalink)
PhilM's Avatar
It is a concern. Does not state whether the throttle butterflies were open when running the compression test as that can be a factor, especially if they are not balanced.
Old 11-19-2012, 11:39 AM   #19 (permalink)
inderocker's Avatar
WOT when testing. 160 was the far left cylinder, which I could not get the tester well seated in.
A963806-2(G)/3(B) Fat Bar Kit fit 2002 955i Speed Triple? escort1991 Speed Triple Forum 2 02-28-2011 01:09 AM
Speed Triple input needed KenB Speed Triple Forum 2 08-03-2009 01:26 PM
Input needed on 2002 purchase bnobles Sprint Forum 3 06-12-2004 01:30 AM
