Originally Posted by jalapenos
I originally missed the waterproof aspect needed, yes the Steve glove is unlined so no moisture protection. The warm n dry glove is very bulky and will be too much in fifty degrees. This comes from someone with poor circulation and frequent cold digits. I still recommend the silk undergloves--they are thin enough to slip under any glove and are quite warm...
so you are saying that the Steve glove will keep your hand warm down to what temps with no heated grips? The liners will add a bit more warmth which is a must.
I basically want a warmer pair of gloves for the fall, down to say 50 Degrees and also if I stay out when the sun goes down I can put on instead of my Air gloves. I have been caught in a couple of showers and I also would like my backup gloves to be waterproof.
So the Steve glove will not cover all those bases.
Maybe the Held Rain storm glove would be better?
