Originally Posted by Speed3
It looks like it is ready to pull right out... Weird. Have you tried a rubber hammer? Maybe rotating the eccentric would free it up. Wild guess.
I tried rolling the eccentric back and forth. Tried a rubber mallet at various points of the eccentric pivot position. It is snagged on something inside. I can rock the axle up and down fractions of an inch but it does not seem to want to rock forward and back?!?!
When I spin it, it sounds perfectly healthy and there is no areas of higher resistance as I spin it.
I even gave it a tap from the brake rotor side to see if would free up the snag by backing it off.
I could put some real effort into the rubber mallet approach but that seems wrong to me to me. Like I am smacking the sealed bearings into the concentric snap ring or something.
I am officially bumming out because this should be a snap to do and it is beginning to look as if something is phucked up in there.
