Motomfg Bike Lift / Paddock Stand Group Buy (Now Extended through Dec 25) - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!
Old 11-11-2012, 03:30 PM   #41 (permalink)
Legend
DEcosse's Avatar
I thought you were conspicuous by your absence!
Make it happen Norm
Old 11-11-2012, 06:31 PM   #42 (permalink)
Main Motorcycle: 2007 Speed Triple
Lord Flashheart's Avatar
Other Motorcycle: 2006 Speed Triple
Originally Posted by DieselGeek View Post
Bumping for interest.
How did I miss this thread ?
What a bad time to be in school....
I am crunching the numbers ...So Much Want
Graduation present!
Remember: "Cs get degrees!"
Lord Flashheart is online now   Reply With Quote
Old 11-12-2012, 10:47 PM   #43 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
* slaps Money on the table *
I'm in
The Speed was my Grad present from first year so this lift will be it for this year .
Let me know when the buy goes down .
Really anyone who does all the work on the Speedy at home should have one .
And the shipping cost to Canada can not be beat .
DieselGeek is online now   Reply With Quote
Old 11-12-2012, 11:52 PM   #44 (permalink)
Legend
DEcosse's Avatar
Greg at Motomfg kindly sent mine on ahead of the full commitment to get a confirmation on fitment for the earlier models.
This is a beautiful piece of kit, even better than expected - very nice quality, everything fits together extremely well.
I have to say I am totally ecstatic with this purchase.
First off, the packing is first-class!
It goes together extremely quickly & easily - put the wheels on, insert the vertical lift component into the base and bolt it together, then finally the adapter plate.
All the bolt holes line up exactly as they should and the powder coat finish is first class.
(Note that the hardware is not Metric - you will need SAE tools - wrenches and hex keys)
The Adapter Bushing is permanently fitted to the bike - remove the lower left-side Frame to Sub-frame bolt, (the one in the pocket in the frame) for which you will need a T55 Torx bit
Then insert the bushing and re-install with the replacement bolt *
* a new nut & bolt will be supplied (original is a flanged bolt)
The adapter bushing only protrudes by about 10mm from the frame, relatively unobtrusive.
Then simply follow the included directions to align the adapter plate and pins between the bike and stand & tighten down. There is excellent range of adjustment built in to the design.
In my case I have Rizoma Rear-sets and I actually used a different mounting hole on the lift frame plate from the recommended hole per the instructions in order to clear the gear-shift pedal.
Very easy to operate and does not require super-human strength to raise the bike. It has good lever advantage. The locking pin is also very nice added safety feature.
It's extremely stable on the stand, even when moving the bike around on it.
Lowering is equally low-effort - you never feel like it is getting away from you dropping on its own weight.
The double casters are REALLY nice - effortless to move the bike around. The two closest to the left side lock to keep the bike from moving when you don't want it to!
I would highly recommend the casters unless you are seriously budget-constrained to not be able to include them at time of purchase:
- you can always get them later if that is the case.
Stand is fairly heavy, so even without considering their best asset of being able to move the bike around, even just moving the stand by itself is much easier to roll than have to pick it up!
I can rotate the bike on its own axis in a single bay of the garage.
Then could move the bike directly parallel to the rear of the garage for minimal intrusion into the garage space.
Before-hand it was in the same general space but only about 45 deg to wall - I would also have to first back the bike into the garage from outside.
Now can ride in, raise bike on the Motomfg Stand, spin it around and push it into the space as in parallel parked!
Here's a wide-view so you can see how tight the bike now tucks into that space:
Old 11-12-2012, 11:57 PM   #45 (permalink)
Legend
DEcosse's Avatar
You're in Norm!
See above I just posted - you're going to love this thing!!
Just one more needed and can start the order process ..................
Old 11-13-2012, 12:35 AM   #46 (permalink)
DieselGeek's Avatar
Would one be able to remove the swingarm with this rig in place?
Old 11-13-2012, 12:39 AM   #47 (permalink)
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '03 Triumph S3
Dang that looks beautiful...
Santa, I've been a VERY good boy this year... so thanks in advance...
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '03 Speedie
My Blog
FoothillRyder is offline   Reply With Quote
Old 11-13-2012, 01:32 AM   #48 (permalink)
Legend
DEcosse's Avatar
One of few things you can't do directly - it uses swing-arm spindle for lower lift pin
But it's not really alone there - you have to either lift under the motor or support under the subframe to do that
So neither Pitbull (or similar design) single-side axle lift nor Abba nor any other type I can think of can accommodate alone.
Here's what I would do:
Lift bike using the Motomfg;
Remove wheel, chain off sprocket, remove right-side spindle bolt and loosen the spindle lock ring & adjuster collar; uncouple lower shock mount from linkage and block under the swing arm to support;
Put a piece of pipe under sub-frame and position jack stands under on each side;
(on some bikes you can just flip the rear foot pegs and support on those)
Lower bike down off stand to support its weight on the pipe (or inverted foot pegs) on the jack stands;
Withdraw the Motomfg;
Remove spindle from left side and withdraw the swingarm.
Old 11-13-2012, 04:56 AM   #49 (permalink)
Dammit DEcosse, now I've got lathe envy. Stand envy, too. Come on, you last holdout - you know you want one.
Old 11-13-2012, 08:39 AM   #50 (permalink)
Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
oldndumb's Avatar
Other Motorcycle: 05SV1K, 2012 Ducati M1100
Kudos to Ken for doing the research and setting up this group buy.
My dealer now sells them and has a Diavel on one one in the showroom. Very apparent that it is well designed, sturdy, and meets expectations.
This is probably one of the best bangs for the buck I have ever seen when it comes to motorcycle related equipment!
Oldndumb
Caveat lector
Group Buy for Paddock Stand / Lift DEcosse Street Triple Forum 20 12-02-2012 07:26 PM
Motomfg Paddock Stand / Lift Group Buy DEcosse Daytona Deliberations 9 11-29-2012 03:17 PM
Motomfg Paddock Stand GB - now incl Sprint DEcosse Sprint Forum 11 11-29-2012 03:15 PM
Bursig or Motomfg Paddock Stand / Bike Lift Systems AKIRA Speed Triple Forum 24 11-04-2012 11:05 AM
Bike lift-Paddock stand Hornblower The Rocket Science Forum 2 03-06-2006 07:19 AM
