Motomfg Bike Lift / Paddock Stand Group Buy (Now Extended through Dec 25) - Page 17 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-04-2012, 07:02 PM   #161 (permalink)
Main Motorcycle: 2002 Triumph Daytona 955i
Afrog's Avatar
Other Motorcycle: 1999 Jeep Wrangler Sahara
Standing up
Success! Finally, that is. Quite the ordeal trying to get the bike balanced front to rear so both tires are off the ground. I still have to finagle the stand into place since I had to angle the adapter plate in order to get both tires up. No simple roll into place and throw the lever. I might try to adjust it more tomorrow, but have run out of patience for that today. And the hex I had to buy was a 3/8 inch for the stand...all the other hexes I've got are metric.
I ended up with a nyloc M10x1.50 nut afterall, despite not seeing the recommendation until after the fact.
All said and done, I'm happy with the stand
Frog
Afrog is offline   Reply With Quote
Old 12-04-2012, 08:54 PM   #162 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
champ87's Avatar
Extra Motorcycle: 1973 Yamaha RD350
Don't waste too much time trying to correct that. If the bike's level when raised then you have the correct settings. The assembly instructions make it quite clear that both pins may not line up and you have to insert one pin then raise the handle to get the stand to "pivot".
At first I didn't understand what could "pivot" because the only movement of the stand is vertical. I wasted a lot of time getting both lifting pins to line up and then wondering why my bike wasn't level when raised. Finally I figured out that raising the handle takes the weight off the stand causing it to tip so both pins align. Simply rolling the stand into place, inserting the pins and lifting is impossible to achieve with my Sprint if I want it anywhere near level. I contacted Greg and he confirmed that is indeed the case. If I'd realized that I could've had this thing set up in 5 minutes. Yes, it's stated quite clearly in the assembly instructions but I was trying to achieve what I saw in the video on Motomfg website. Maybe that applies to some bikes but definitely not my Sprint.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline   Reply With Quote
Old 12-04-2012, 10:20 PM   #163 (permalink)
Legend
DEcosse's Avatar
Originally Posted by champ87 View Post
.... Simply rolling the stand into place, inserting the pins and lifting is impossible to achieve ....... Maybe that applies to some bikes ....
Recognize that applies with the Sprint, (& also the Street) Champ:.. With my and Jeremy's S3 set-up it was indeed possible to slide in and still have both ends off the floor - therefor it should be possible for the Daytona also (if desired) - that's more a bonus for us than a detriment to the others, given that the fundamentals expect the pins will not align
But the best advice as you suggest is just to set up per the recommended procedure and learn/practice operating technique
Old 12-08-2012, 01:57 PM   #164 (permalink)
Main Motorcycle: '11 Blaze Orange S3-R
Thumbs up thanks decosse...
I received my stand on Thursday, and just got finished putting it together. The whole process took about an hour, 15 minutes of which was spent at the neighbor's to get a 3/8" hex wrench (all the bolts are SAE). For anyone still on the fence, this is a quality stand and will really make working on the bike easier. Being able to wheel the bike around alone is worth it, so be sure to add on the caster set.
mcouper is offline   Reply With Quote
Old 12-09-2012, 09:38 AM   #165 (permalink)
Main Motorcycle: 2009 Speed Triple
drsib's Avatar
Add me to this group. Once I abandoned the notion of "level", I now have a setup that allows me to slide and lift with ease...pretty much like the video. This stand becomes more awesome every time I use it!
drsib is offline   Reply With Quote
Old 12-12-2012, 01:02 AM   #166 (permalink)
Main Motorcycle: 02 SkeleTona 955i CE
Nelsifer's Avatar
Do you think there will be another group deal after this one ends. I'm tapped out after holiday shopping for the family. 13% may not sound like much but I'm planing on getting the the 46mm socket and the chain adjuster. It adds up.
Ride fast, take chances...
-Reupholstered Seats
-Bar Conversion
Nelsifer is online now   Reply With Quote
Old 12-12-2012, 01:16 PM   #167 (permalink)
Legend
DEcosse's Avatar
Originally Posted by Nelsifer View Post
Do you think there will be another group deal after this one ends.....
Sorry, can't see it - after the original period closed, there have been no additional respondents added this month.
Old 12-13-2012, 12:07 AM   #168 (permalink)
Main Motorcycle: '12 Street Triple
Anyone know if they would sell an extra bushing? I think that is what the part that goes on the bike is called. My brother has an 09 street and i have a 12 and we were thinking of splitting the cost for one but would need two of the pieces that go on the bike.
Thanks!
jbamerica is offline   Reply With Quote
Old 12-13-2012, 12:38 AM   #169 (permalink)
Legend
DEcosse's Avatar
I would expect not to be an issue - shoot him email
Old 12-17-2012, 02:17 PM   #170 (permalink)
Emailed the "sales@motomfg" on thursday. Havent heard back. Is that the right address?
Group Buy for Paddock Stand / Lift DEcosse Street Triple Forum 20 12-02-2012 07:26 PM
Motomfg Paddock Stand / Lift Group Buy DEcosse Daytona Deliberations 9 11-29-2012 03:17 PM
Motomfg Paddock Stand GB - now incl Sprint DEcosse Sprint Forum 11 11-29-2012 03:15 PM
Bursig or Motomfg Paddock Stand / Bike Lift Systems AKIRA Speed Triple Forum 24 11-04-2012 11:05 AM
Bike lift-Paddock stand Hornblower The Rocket Science Forum 2 03-06-2006 07:19 AM
