Speed Triple Exhaust Cleaning - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 11-04-2012, 08:15 AM Thread Starter
Main Motorcycle: Speed Triple 1050
Looking at the exhaust system on my S3, I notice some discolouration of the metal and road grime beginning to build up. Read the maintenance manual, gave it a wash but I'm seeking advice before attacking the metal with anything that might have me regretting my actions. Triumph also recommend Motorex 645 which seems a rather expensive product and not stocked locally - I'd appreciate your tips and shared experiences.
Oops! is offline
post #2 of 12 (permalink) Old 11-04-2012, 08:52 AM
Harpic Blue Toilet Cleaner
Believe it or not, I have found the best S/S cleaner (especially for burned on crude on exhaust pipes, as well as the burnishing caused by heat), to be:
Harpic Blue. If this product is not available in your location look for a similar toilet cleaning liquid with the following chemical composition: Tallow Trimethylammonium Chloride 0.47% m/m
Application: Use an old toothbrush and a small amount of water - leave for 5 minutes and then washing it off. Reapply if surface badly coated with burned on street crude.
Note: This product only works on Stainless Steel and not Chromium finishes. While gloves should be used when applying the product, there is no reaction to aluminium engine cases -- I tried this out to make sure!
Important Note: None of the other Harpic 'colours' work! In other words they have different chemical compositions.
Talking to a rep here in South Africa the formula in the blue bottle is the same used commercially to clean S/S urinals
DeanRider is offline
post #3 of 12 (permalink) Old 11-04-2012, 10:12 AM
Main Motorcycle: 2012 speed triple
tim-s's Avatar
Extra Motorcycle: the wifes
I use this with some good results
http://www.getgeared.co.uk/OptiGlanz..._Steel_Cleaner
It's pretty strong so I'd recommend rubber gloves & some sort of eye protection.
I tend not to spray it on but put it on a scourer & give it a good rub.
life's to short to ride an ugly bike
tim-s is offline
post #4 of 12 (permalink) Old 11-04-2012, 10:14 AM
Main Motorcycle: 2014 FZ09
I just use Mothers Mag Polish... I also use a non caustic household SS appliance cleaner for regular cleaning. The Mothers will really make the pipes gleam. I avoid using caustics at all costs, if I have to wear gloves to use it, I don't want it near painted surfaces
2014 Blazing Orange FZ09
2011 Crystal White S3-SOLD
Speedycaptain is offline
post #5 of 12 (permalink) Old 11-04-2012, 11:07 AM
Main Motorcycle: '01 Speed Triple
I've used this stuff with great results
http://www.jpcycles.com/product/440-...FY-d4AodIGgAzg
Speed3 is offline
post #6 of 12 (permalink) Old 11-04-2012, 11:45 AM
Main Motorcycle: 2011 S3
I have had great success with Nevr-Dull. I like wadding polish for pipes, helps to scrub off road crud.
bevivino1 is offline
post #7 of 12 (permalink) Old 11-04-2012, 11:51 AM
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
the best in my experience, and you can pick it up cheap at any Love's or Pilot truck stop
http://compare.ebay.com/like/1607209...Types&var=sbar
SUPPORT THE TROOPS!!
Joe Houle is offline
post #8 of 12 (permalink) Old 11-05-2012, 04:16 AM Thread Starter
Thanks fella's,
Appreciate you sharing your varied tips ............ an evening in the garage beckons.
Oops! is offline
post #9 of 12 (permalink) Old 11-05-2012, 11:10 PM
Main Motorcycle: 09 Speedy
DFUSEME's Avatar
Hey? What year is your bike??? Are u running this stock exhaust?
Keep the rubber side down!!!
DFUSEME is offline
post #10 of 12 (permalink) Old 11-06-2012, 04:43 AM Thread Starter
Currently running the stock exhaust on a 2012 S3. Interesting number of different metals/finishes that make up this unit - all to be kept spick and span.
Oops! is offline
speed triple gp exhaust on street triple? shift250R Street Triple Forum 0 05-10-2011 10:53 AM
Exhaust Help for '09 Speed Triple SpeedTrip09 Speed Triple Forum 0 09-20-2010 10:23 PM
speed triple exhaust jackrunner Speed Triple Forum 8 03-10-2009 04:49 AM
99 Speed Triple Exhaust deviantkitty Speed Triple Forum 3 01-09-2008 05:19 AM
