Compatible Coolant - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Old 10-24-2012, 07:16 AM   #1 (permalink)
Newbie
Main Motorcycle: Speed Triple 2012
Compatible Coolant
Are there any coolants recommendable other than the triumph HD4X? Triumph brand seems difficult to get/expensive and I'm exploring my options.
On another note my Bike is 3-4 months old, has 5000km has been serviced twice (once for first service and once because it ran very low on oil) at about 4700 km she had more than enough coolant, but 400 km later she has run almost dry. I'm a bit of a newbie and I'm wondering if this is usual, or something to be concerned about?
Spartoob is offline   Reply With Quote
Old 10-24-2012, 09:11 AM   #2 (permalink)
Main Motorcycle: 2011 S3
I am not sure about which coolant to use, but I can tell you if you coolant level is almost empty, that sounds like a serious problem and I would be talking to the shop who did the service. I have no idea where the coolant could have gone either.
cognosticator is online now   Reply With Quote
Old 10-24-2012, 12:03 PM   #3 (permalink)
Main Motorcycle: '08 S3
Equito's Avatar
Other Motorcycle: '04 Concours
Extra Motorcycle: '01 ZRX, '98 VFR
I use the Honda blue bottle pre-mix in all of my bikes. No silica is key. Compatibility with aluminum cooling systems and engine parts is key. Not cheap, though - nothing good ever is.
Equito is online now   Reply With Quote
Old 10-24-2012, 12:19 PM   #4 (permalink)
Main Motorcycle: '11 Speed Triple SE
I use Engine Ice, but I would take that thing to the servicing dealer ASAP.
Tbone is offline   Reply With Quote
Old 10-24-2012, 02:36 PM   #5 (permalink)
Main Motorcycle: 2001 Trophy 1200, T509
Other Motorcycle: Norton Commando MK 3
Extra Motorcycle: 1968 BSA Thunderbolt
Almost dry as in in the radiator, or almost dry as in in the overflow tank? Tank may not be an issue as it doesn't hold much (watch it though), radiator on the other hand is something to be concerned about.
rubber biscuit is offline   Reply With Quote
Old 10-24-2012, 08:54 PM   #6 (permalink)
Main Motorcycle: SIII 1050 07'
mnhoulden's Avatar
You or they may not be filling up the coolant properly. I use the green stuff 50/50 and it works fine.
You need to make sure you are filling and running your bike so you get all of the air out and don't forget to top up the overflow too.
Cheers,
Mark
www.azdirtyaces.com Motomarathon, CO. 2010 ASMA #309 IBA#34978~ SS1000~ 10.11.08 B2B Insanity~ BB1500~ 10.17.10
Alaska Blog- http://3umphak.wordpress.com/
mnhoulden is offline   Reply With Quote
Old 10-25-2012, 12:13 AM   #7 (permalink)
Newbie
Just the overflow, the radiator was fine. I ended up going to the dealership and they recommended Motul inugel expert. Bit different from the green crap I flushed out of it but it seems to work.. Thanks for your help guys.
Engine ice was also mentioned by the dealer, I may swap over to that in the not too distant future; the bike seems to run a bit hot and summer is coming up.
Old 11-14-2012, 08:53 PM   #8 (permalink)
Main Motorcycle: 2004 Speed Triple
flashotter's Avatar
I did a little research on what type of coolant Maxima Coolanol seems to be perfect replacement for us because it uses ionized water and is extremely low sillicate. Bikebandit had lowest price.
flashotter is online now   Reply With Quote
Old 11-15-2012, 12:28 PM   #9 (permalink)
Main Motorcycle: '01 Speed Triple
Why not eliminate water completely, and go with Evans? I've used it for years. I changed it last year, after being in the bike since '04, and it looked like new. Good stuff.
http://shop.edoperformance.com/evans...n-p-33638.html
Speed3 is offline   Reply With Quote
Compatible Seats d00dge Twins Talk 0 08-28-2012 02:16 PM
RE Mudguards compatible? TheFixer Twins Technical Talk 1 04-14-2012 09:27 PM
Compatible headers slatept Hinckley Classic Triples 2 02-29-2012 09:57 PM
Which Pegs are Compatible prican_2000 Triumph SuperSports 2 04-16-2011 12:20 AM
Compatible wheels? speed3shon Triumph SuperSports 2 06-16-2008 02:26 AM
