08 Speed Triple ignition problems (stator) - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-01-2012, 08:16 PM   #31 (permalink)
Main Motorcycle: 08 Speed Triple
kippernicus's Avatar
Been a week now since the stator was put in and it's still starting up fine. Turns over about 5 or 6 times before it fires up though (even when engine is warm). Not sure if that's normal. Liquid gasket is holding up perfectly. No leaks from what I can tell.
I'm having a new problem now. When I crack on the throttle at around 4-6k rpm I can hear a very distinct "crackle" coming from the front of the bike. It only happens when I'm driving though. If I test it while parked, everything sounds fine.
Sidenote: Does anyone else use "Royal Purple" 10/40?
kippernicus is offline   Reply With Quote
Old 11-01-2012, 10:14 PM   #32 (permalink)
Main Motorcycle: '08 S3
Equito's Avatar
Other Motorcycle: '04 Concours
Extra Motorcycle: '01 ZRX, '98 VFR
1. Consider keeping the bike on a batterytender. Lots of starts pull the battery down and insufficient road time means the charge doesn't get put back. Keeping it charged up means solid power to the starter and related gears (avoiding sprag clutch damage), and the battery lives a lot longer because it's not sacrificing its guts to keep the volts up.
2. "Crackle" roll-on may be detonation. Make sure you're using Premium fuel and the LATEST '08 map (find on TuneECU site, or have a dealer do it). The earlier '08 maps have too much ignition advance (or too little fuel) and mine detonated like crazy until I downloaded the newest map. Day/night difference. Might help a quicker start, but don't know.
Equito is offline   Reply With Quote
Old 11-02-2012, 05:02 AM   #33 (permalink)
Legend
DEcosse's Avatar
Originally Posted by ilovheros View Post
http://signaldynamics.com/index.php/...eyword=voltage Anyone order one of these? ...
... Anything better in the market I would like to know.....
This is the one I recommend in the Sticky thread and use personally on both my bikes -
http://www.ebay.co.uk/itm/12v-LED-Ba...item23093fd67d
Comes in three LED sizes, I prefer the smallest one myself.
There are pics of it installed in the sticky thread. Great little device and fabulous service - quick low-cost shipping from UK, you'll still be way ahead in cost vs the SC unit - and is tiny also vs that big control box on the SD unit!!
Old 11-02-2012, 09:02 AM   #34 (permalink)
Main Motorcycle: 08 Speed triple / white
ilovheros's Avatar
Other Motorcycle: VFR 800/abs
Thanks D. Missed that too. That is the one I will get.
ilovheros is offline   Reply With Quote
Old 11-02-2012, 04:10 PM   #35 (permalink)
ilovheros's Avatar
Allright, installed my new Shorai 18 battery today. Bike started right up, like a champ. 50* here in Cinci. Checked the battery with the motor not running. Had 13.42. Started it and got 13.65 at idle. Revved to 3-4 and it ran up to 14.08. Went for a 1/2hr ride. Tested again, 13.49 off, key on only, 13.12, idle 13.65, with revs 14.35 constant. Strator is good and so is my old R/R it seems. Question? Should I still change the R/R to the upgraded unit that I bought? I think It would be good ins. but I could just order the Monitor that D recommended and watch things.
Old 11-02-2012, 04:24 PM   #36 (permalink)
Main Motorcycle: SIII 1050 07'
mnhoulden's Avatar
Put in the updated R/R. The lil light doesn't tell you exactly when the R/R will fail.
Also have you thought about putting in heavier gauge wires for the battery to starter and ground? I did this and it makes a world of difference to the starting of my bike.
I believe DeCosse has a how to sticky...
Cheers,
Mark
www.azdirtyaces.com Motomarathon, CO. 2010 ASMA #309 IBA#34978~ SS1000~ 10.11.08 B2B Insanity~ BB1500~ 10.17.10
Alaska Blog- http://3umphak.wordpress.com/
mnhoulden is offline   Reply With Quote
Old 11-03-2012, 09:32 AM   #37 (permalink)
ilovheros's Avatar
I bought the plug and play Triumph cable for $8.50 but don''t have it yet. Can I still wire direct to the battery along with the New cable? I have not removed the tank to look at the R/R wiring yet.
Old 11-03-2012, 11:49 AM   #38 (permalink)
Legend
DEcosse's Avatar
If you are getting the plug n play cable, just use as-is and plug in as intended.
You would have to rework the Triumph cable in order to connect direct to battery - I've seen more issues caused by inadequate techniques in execution of that than are intended to fix, with this high current circuit.
Old 11-04-2012, 11:18 AM   #39 (permalink)
I was really hoping that it was a mapping error. I'll have to get it into a shop soon. Thanks Equito.
Old 11-05-2012, 08:49 AM   #40 (permalink)
Main Motorcycle: Triumph
Other Motorcycle: Suzuki GSXR.
Extra Motorcycle: VTX1300
From everything I have read, replace the RR with MOSFET type as first order of things to do. As stated there is no way to tell when the original one goes and when it does, it will put a huge load on the stator and possibly take it out.
flyingz is offline   Reply With Quote
Speed triple stator problem unsolved-doesn't fit Zarathustra Speed Triple Forum 19 10-26-2011 07:58 PM
Street triple Ignition Problems!! AC3 The Welcome Center 1 09-03-2011 11:32 AM
07 speed triple stator britmick Speed Triple Forum 2 07-22-2010 02:54 PM
955 Speed Triple stator burnt out degsy24 Speed Triple Forum 9 07-20-2010 09:13 PM
