Two points:
I have been told that it is safe to jump start a bike from a car, but only using bike specific jump leads. Car sized leads allow too much current to be drawn, which can fry a bike battery. Never actually experienced this, but better safe than sorry.
You should never push start any vehicle, bike or car, which is fitted with catalysts, as this can soak them in fuel, which ignites once the engine is running and wrecks them. This may not be true of all FI systems, but again better safe than sorry.
If your bike is fitted with an alarm there will be a small current drain, which over time will flatten the battery. It's not a fault with either the alarm or the battery, it's just the physics. Something like an Optimate will solve the problem.
Bother, that's three points.
