Old 01-04-2006   #1 (permalink)
Favorite Bike: Speed Triple
Other Motorcycle: SV650
Extra Motorcycle: Ducati SS1000
I was hoping to fit clip-ons onto my '06 triple. I bought the LSL set with 1" rise in which the bars mount in front of the triple clamp to give me a longer stretch as I'm 6'6".
I was dissapointed to find the clip ons contact the clocks with just a few degrees of turn, no way for it to work out. So I'm out the $240 I spent on the clips ons and bars. Cyclecat claims to be developing a set.....
Looking around, I found the LSL single headlamp conversion that mounts the light to the forks, can't tell for sure but it looks like the clocks stay stationary.
As I wish to retain the stock dual lights, I wonder if the stock headlights and clocks could be mounted to the forks instead of the frame. This would allow the use of the clip ons.
Anyone done this?
lromoda is offline   Reply With Quote
Old 01-04-2006   #2 (permalink)
buy a set of woodcraft clip ons for $150
some on here have them and they work fine but no 1" rise
My speedy is for sale, let me know if your interested.
brettmess24 is offline   Reply With Quote
Old 01-04-2006   #3 (permalink)
I just put on some SV650 type 2 bars from www.suburban-machinery.com. They are not as low as clip ons but clear everything including the flyscreen.
littlefield is offline   Reply With Quote
Old 01-04-2006   #4 (permalink)
Do the clip-ons only hit the guage cluster and not the headlamps? If so, there should be several screw holes around the ignition switch on the bottom side of the top clamp where you could mount a bracket for the guage cluster. My Roadracing fairing does this and includes such a bracket. If you like, I could have a copy made if you send me a paper maquette of your current guage cluster mount so I can get the bolt pattern right. I don't know of the 05+ is the same as the 02-04 guages.
Old 01-04-2006   #5 (permalink)
i thought about doing this too. you'll have to prob make something custom to remount the gauge cluster and in addition to that, there isnt a whole lot of room inbetween the cluster and the ignition.
which is what made me think that the entire cluster (which i think is a bit ugly) should be replaced with 2 billet pod style tacho and speedo. but then you loose all the functions of the cluster.
anywho... i digress.... if you come up with a good solution lets us all know. good luck.
bikeordie is offline   Reply With Quote
clocks akenaten Twins Talk 28 11-29-2007 09:09 PM
Rear Wheel Remounting Problem: II Mancha Twins Technical Talk 8 03-20-2007 09:29 PM
Clocks straightline The Rocket Science Forum 9 11-17-2005 03:09 AM
Clocks mjudkins Sprint Forum 1 08-28-2005 07:27 PM
S3-05: How turn off headlights? TM Speed Triple Forum 11 06-21-2005 07:09 AM
