Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
BikeBandit
Old 01-02-2006   #1 (permalink)
Favorite Bike: 2004 S3--black
FelixLeiter's Avatar
Location: Where the oil comes from...no, not over there
So, I got a GPS for Christmas which I am going to exchange for a higher end model. The one I have is a Magellan eXplorist 200-- no ability to upload detailed maps nor an electronic compass (only satellite based compased which doesn't work whilest unit is stationary). I'm leaning towards the Magellan eXplorist 600 because it has an SD memory card slot for unlimited downloaded maps, an electronic compass, colour screen, rechargeable batteries, etc...
I have no idea how much memory I would need in a unit to hold lots of maps...a lot of the other mfgrs have units with built in memory (not expandable thru SD cards as the Magellan is) but how much is enough?
Any opinions on whose GPS units are better? I require one that is also handheld for backcountry use-- rules out any of the vehicle specific models.
Thanks.
Yr Fthfl Srvnt
FelixLeiter is offline   Reply With Quote
Old 01-03-2006   #2 (permalink)
Favorite Bike: 2006 Triumph Speed Triple
AttackPug's Avatar
Other Motorcycle: 2001 Honda Goldwing
Extra Motorcycle: 2007 Triumph Tiger
I have a Garmin GPS V it only holds maybe a days ride then I have to reload maps for the next day. I think the high end Garmins will hold alot
IBA # 33267
AttackPug is offline   Reply With Quote
Old 01-03-2006   #3 (permalink)
The Garmin Streetpilot 2720 is an awesome little machine. Fully gasketed so it'll hold up in rain while riding mounted to the bars. I'm not sure if the 2620 or other models are gasketed, but definitely look for something waterproof. It would suck to spend hundreds of dollars on a GPS just to have it get fried in the first unexpected rainfall that hits it.
Old 01-03-2006   #4 (permalink)
Newbie
Any GPS with a Compact Flash (CF) or Secure Digital (SD) card slot will give you just about unlimited map capacity, some of the units like the Garmin 2620 mentioned come pre loaded with everything on them others require you to buy a DVD or CD to load the info. I have a Garmin Legend with 24 MB of memory and can load the state of Oregon on it. Try these sites on the web (good info) www.gpsnow.com or www.thegpsstore.com :-g :-g
dwkelly3 is offline   Reply With Quote
Old 01-03-2006   #5 (permalink)
If you are considering the Garmin, I would not consider the 2620 for motorcycle use, it has the entire map database loaded but it uses a harddrive and the vibrations it will be subjected to on a bike will likely damage the HD..it'll work forever in a car though. I would strongly advise you go for the 2720 (brand new w/ 3D map- uses non-volitile flash storage somewhat like the iPod Nano) or the 2610 that uses the compact flash card (a 2gb card will hold just about the whole world on it w/ room to spare).
The 26xx series Garmin GPS actually has more user accessible 'bells and whistle' features than the newer 2720 unit w/ the 3D map but both have more features and functions than you can shake a stick at and neither seems deficient on the feature set. Get thee to a best buy and have a poke around.
I personally use a Garmin GPSmap 60cs, the smaller general handheld version. I find the S3 to be such a naked bike that the larger form factor of the 26xx or 27xx models of the Garmins just looks too big and overscaled on the bike. I purchased a power cable from cycoactive.com (garmin also sells one), the handlebar mount from Garmin and it snaps tidily on your handlebar between the clamps and operates either by power cable or AA batteries. You will need to also purchase the city navigator map software and it does have limited non-expandable memory (56mb) which is good for about a 4 state area, its navigational performance is absolutely superb; it's fast, the transreflective LCD screen is just about the best I've ever seen, very viewable in regular daylight, and just doesnt lag. It's few downsides are the limited memory capacity and limited screen size, but my eyes are good and it works for me. The garmin power cable has a earphone connector so that you can use a set of headphones to hear the system beep at you when a turn is coming up or if it's recalculating your route, it generally allows you to focus on the road and not the unit until it's appropriate to take note of the unit, otherwise you find yourself being distracted by the GPS unit a bit more than is wise. It also has a compass, barometer, and other general GPS features included that makes it an awesome overall unit. I like it a lot.
There is the Garmin Quest2 that has the US fully loaded on it and it also is a more compact GPS unit that has a motorcycle specific mounting/power kit (RAM mount). It is not quite as feature filled as the GPSmap 60cs as it is a road navigation focussed unit (very appropriate for cars and bikes) and it's orientation is horizontal (landscape)rather than vertical (portrait) like the GPSmap, in my opinion, this limits how much fore of the route ahead you can preview, otherwise also a neat unit. All these suggested Garmins are sealed and very weather proof.
I have tried and owned a variety of GPS units over the years and I always seem to come back to Garmin.
TomTom has just released the Rider, designed specifically for motorcycles, check out this early review. I'm tempted to give it a go but I'll see about tracking it down and fiddling with it first.
also try this link, it contains great info on just about every GPS unit out there and is very, very informative. If that cant help you make a well informed decision, nothing will... :-D
rudebwoy85 is offline   Reply With Quote
Old 01-03-2006   #6 (permalink)
Thanks for the info guys. I want to stay away from the vehicle specific gps models because I also plan on using it when I travel (almost got lost on a trek into the mountains north of Puerto Vallarta last year because of a lack of maps available in mexico) and when I hike in the backcountry ( I only live a few hours from the Rocky Mountains). One of my concerns was how much mapping info is held in XX Megabytes. Sounds like the Garmin 60CS may be too small, and at 115MB the 76CS would likely be enough but it is $130 more than an equivalently equipped Magellan eXplorist 600 which uses an SD card. I have had the same 120 songs on my iPOD shuffle for the last 6mo. so I may be too lazy to reload a gps with a limited memory.
The other big question was whose maps are better? I could find no definative data on the web. Both respective manufacturers' websites stated that the license for the mapping software was good for one gps or one sd card but is there anything that would stop me from finding someone who has a map software I want and just copying it onto my gps or sd card?
Yr Fthfl Srvnt
Old 01-03-2006   #7 (permalink)
Get the Garmin Quest II. The only choice.
redwhiteblue is offline   Reply With Quote
Gps Triumph FF Twins Technical Talk 10 09-16-2007 03:45 PM
electrical/wiring question for GPS - help! Orpheus Twins Talk 7 04-28-2007 10:18 PM
GPS boxsky Sprint Forum 19 05-06-2006 12:36 PM
Viewing GPS question Whisperinsmith Sprint Forum 3 04-05-2006 02:50 PM
GPS V kann Sprint Forum 5 06-30-2004 09:23 PM
