Motorcycle.comRacerPartsWholesaleBikeBanditSpringfield ArmoryMotorcycle.com Classifieds!ShopTriumph.comSportbikeTrackGearAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 01-02-2006   #1 (permalink)
greenocktriple's Avatar
Hi all,
Looking to see if anyone can suggest any type of clutch kit to replace on my 2k model,anyone fitted one recently?if changing did you use upgraded springs or are standard ones ok to re-use?
cheers.
BETTER A DAY AS A LION THAN A LIFETIME AS A SHEEP.
greenocktriple is offline   Reply With Quote
Old 01-03-2006   #2 (permalink)
I recently replaced the clutch in my 1999 S3 with 30,000 miles, and could not find aftermarket plates and springs. I went with OEM and was advised to get new springs to be on the safe side. Six new springs at $4 USD each was worth the peace of mind. I believe total cost for the clutch parts was under $300 USD.
BShell is offline   Reply With Quote
Old 01-06-2006   #3 (permalink)
cheers b shell,found a supplier ebc full set of plates and upgraded springs,£60,only friction plates mind you.thanks again.
footpeg lowering kits/shift and brakelever extension kits, and more ultracyclist Twins Technical Talk 0 01-12-2008 10:58 PM
tool kits hkt100 Twins Technical Talk 6 01-04-2007 02:20 PM
shim kits patrol21 Hinckley Classic Triples 5 09-07-2006 07:37 AM
AI Kits - Which is best NHScrambler Twins Talk 2 06-10-2006 06:27 PM
Fastener Kits ncd650 Triumph SuperSports 1 02-17-2006 06:45 PM
