Missed shifts with Sunline - Triumph Forum: Triumph Rat Motorcycle Forums
Old 09-01-2012, 03:12 PM   #1 (permalink)
Main Motorcycle: 08 Speed triple / white
ilovheros's Avatar
Other Motorcycle: VFR 800/abs
Thumbs down Missed shifts with Sunline
I had been following the thread on the Sunline shifter and decided to get one even though I have never had a problem with how the Speed shifted. Shifting is now a very light touch affair which I like but clutch-less up shifts are horrible especially from 4th to 5th, I have missed more shifts with more false neutrals than ever. Downshifts are off too. I never have had this problem before. There is NO WAY I would take Speedy to the track like this. I really would like to switch back but I cut the rubber boot and installed it on the Sunline. Is anyone else having this problem and what did you do.
ilovheros is offline   Reply With Quote
Old 09-01-2012, 03:17 PM   #2 (permalink)
Main Motorcycle: 2009 Speed Triple
DR_METZ's Avatar
Surprised to hear this. My experience is quite different from the one you described. After installing the Sunline Shifter, I felt more connected to the bike. Hopefully you'll get it sorted out.
DR_METZ is offline   Reply With Quote
Old 09-01-2012, 03:46 PM   #3 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
You def have it adjusted wrong. Check that it has full range of motion and isn't fouling against the front sprocket cover..
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 09-01-2012, 04:34 PM   #4 (permalink)
Main Motorcycle: 06 Speed Triple
Joemomma's Avatar
Other Motorcycle: 99 SV 650
Extra Motorcycle: 03 WR250F
Is the arm folding in on you? Is it adjusted correctly? BTW, the rubber boot is inexpensive and available at Bike Bandit or any Triumph dealer, if you want to switch back.
My experience has been the opposite...I now have an MSR shifter, sans linkage, and a CRG clutch lever. It feels much more connected, and even if I wear sneakers ( very rarely ) I get nice clean shifts.
insert clever saying here...
Joemomma is online now   Reply With Quote
Old 09-01-2012, 07:59 PM   #5 (permalink)
Main Motorcycle: 2007 Triumph Speed Triple
Ebster1085's Avatar
Like the other posters above, I also love my Sunline and find that shifting is crisper and more mechanical. I have literally not missed one shift since putting on the lever.
Make sure it is tightened down with the lever as far out to the left as possible. Also, try a different position and see if you like that more. I have mine in pretty much the same position as the OEM unit and it works great for me.
LSL Damper CRG Mirrors OES Sliders CF Frame Covers CF Heel Plates CF Tank Pad CF Rear Hugger Sunline Shifter LED FE Kit MIVV CF Slip On TuneECU K&N Air Filter FH012AA R/R Stoltec Starter Cables The2Wheels Levers Rick's Hotshot Stator
Ebster1085 is online now   Reply With Quote
Old 09-01-2012, 11:08 PM   #6 (permalink)
Main Motorcycle: 08 Speed Triple
wabill's Avatar
Other Motorcycle: 06 Ducati S2R1000
Extra Motorcycle: Yamaha FJR1300
The only problem has been wear on on left boot. 25 cents worth of shrink sleeve has taken care of that issue. No other problems in a year of use.
DON'T WORRY, BE HAPPY!
wabill is offline   Reply With Quote
Old 09-02-2012, 08:09 AM   #7 (permalink)
ilovheros's Avatar
When I installed it I tried to set it like the oem was but it really would only go on (in and out on the spindle) one way. The attaching bolt had to slide where the slot is on the spindle. It is at the very outside of the spindle. It does seem to fold some times when downshifting but its the constance missed power shifts that have me concerned. It will do this almost every time under hard power up shift, no clutch.. Should I try to move it in closer to the bike? Maybe there is too much leverage? Like I said it is a very light touch now... Rizoma rear-sets are way too expensive.
Missed shifts with Sunline-dscn0915.jpg   Missed shifts with Sunline-dscn0912.jpg   Missed shifts with Sunline-dscn0914.jpg
Old 09-02-2012, 08:37 AM   #8 (permalink)
Ebster1085's Avatar
From looking at those pics, I would say you should lower the footpeg a bit. It looks, at least to me, like it is too high for a comfortable ergonomic shift.
The slot in the spindle goes all the way around the circumference of the spindle, no? Just totally remove the bolt from the new shifter, slide it on where it is the most ergonomic, and then reinstall the bolt and tighten down.
Old 09-02-2012, 02:34 PM   #9 (permalink)
Joe Houle's Avatar
Yep, lower it 2x teeth then test ride
Old 09-02-2012, 04:31 PM   #10 (permalink)
DR_METZ's Avatar
Looks a little high...lower it a little like the others have suggested and give it another shot
Need a Sunline Shifter mkolankowski Speed Triple Forum 7 11-06-2011 06:39 PM
Missed Shifts loadedmind Speed Triple Forum 10 04-27-2011 07:53 AM
foot boards and heel/toe shifts DebInOz Cruisers - America, Speedmaster 5 11-04-2009 08:00 PM
Missed Shifts mvoutour Speed Triple Forum 5 10-15-2008 04:49 PM
shifts better/worse at different rpm's tekmoe Speed Triple Forum 32 08-08-2006 12:17 PM
