Slight stuttering/vibrartions when breaking. 2011 speedy - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-09-2012, 07:13 AM   #41 (permalink)
Main Motorcycle: Speed Triple
Well I hope that fixes your problem for good.
I too had the same problem that you were describing and in fact still do. I had my disks/rotors (which aren't made by Brembo by the way, only the caliper and pad are Brembo) swapped last year which also fixed my problem initially.
However (and I hope this doesn't happen to you) the vibration came back 2 weeks later. The dealer looked at my disks and then sent pictures to triumph and noted the disks were pitted. They said that this pitting was causing my judder but refused to do anything about it, despite it happening 2 weeks after they were new.
I have found that over drier periods (which doesn't happen very often in the UK), and if I break hard and often the problem goes away, but it always comes back when its wet again.
So basically I think that under my normal ridding (I commute on my bike, so don't ride it hard as much as I would like) the disk being made out of cheap material, corrode faster than I wear them. But if you can wear them faster than they corrode you wont see the problem.
Hope that helps - I do feel your pain
SpeedyStu is offline   Reply With Quote
Old 11-10-2012, 01:55 PM   #42 (permalink)
Main Motorcycle: S3 2011 ABS White
Wow, that doesn't sound very encouraging. Weather being as it is, I probably wont get much riding done more this year. Fingers crossed that the problem is gone, if it comes back I guess the next course of action would be to change the rotors to some more high quality stuff. Probably wont find out till next summer though. I did some hard riding (couple of trackdays) and one pretty long trip (3500km+) and almost daily riding besides that, one would think that it would keep the corrosion away. But I guess we'll see.
Thanks for sharing
Hymn is offline   Reply With Quote
2011+ Speedy custom tunes drz1050 Speed Triple Forum 1 05-27-2012 03:45 AM
Breaking in a 2011 Bonnie HUBA Biker Hang-Out 25 02-22-2012 06:14 AM
2011 Speedy risers & handlebars. Oz Rogue Cruisers - America, Speedmaster 6 04-01-2011 06:46 AM
2011 Speedy sissy bar and rack Trev10 Cruisers - America, Speedmaster 1 03-24-2011 07:21 PM
2011 Speedy in USA? Grendel Speed Triple Forum 1 03-15-2011 12:11 PM
