BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 12-15-2005   #1 (permalink)
I am making a rear stand for my s3 and was hopeing someone on here would help me out with something. what is the diameter and length of the pin that goed in the axle? also i have seen them for the right and left hand side what is the difference?
thanks
Agkistrodon is offline   Reply With Quote
Old 12-15-2005   #2 (permalink)
There shouldn't be a difference for left or right. A good rear stand should be able to be used on either side. Otherwise, you'd need one stand for chain/sprocket swaps and other to take off the rear wheel. Centerstand is best. It doesn't add a lot of weight, won't drag until you've worn your footpegs off, and you can use it anywhere.
Old 12-15-2005   #3 (permalink)
To answer your question, check out *cough cough* skyking's long handled SSSA stand.
Old 12-16-2005   #4 (permalink)
I want to practice my welding so i will be making one out of angle iron. i was just curious how far through the axle the pin went.
Old 12-18-2005   #5 (permalink)
I have an LP-USA SSSA-stand.
The pin diameter is 27.8mm (1.10in)
The pin length is 45.7mm (1.80in)
The pin is not as long as I would have hoped. If it were much longer, it just might snap off
good luck!
I hope you trust your welding as much as you value your ride!
lotustype26 is offline   Reply With Quote
Old 12-28-2005   #6 (permalink)
Favorite Bike: 2005 Black Speed Triple
TonUp's Avatar
Other Motorcycle: 2007 Suzuki V Strom 650
Extra Motorcycle: 1974 BMW R90/6
I have a PIT BULL and I really like it. Looks great too!
Ton Up!
Bennington Triumph Bash 2009
TonUp is offline   Reply With Quote
Old 12-28-2005   #7 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
On 2005-12-15 18:48, kuhlka wrote:
There shouldn't be a difference for left or right.....
There is - I have a reversible one-arm Pitbull and the pins are different for left & right side operation.
Sorry- I don't have a caliper to measure them Agkistrodon
GSXR 1000 Front End Swap
Old 12-28-2005   #8 (permalink)
There is a difference between the two sides. The left is snaller than the right. I don't have exact measurements either. For 165.00 you can have the pitbull reversable, if it breaks you get a new one, if it breaks with the bike on it they are liable.... FYI
Isn't that Special...
Geof3 is offline   Reply With Quote
front and rear stands sodapop Sprint Forum 4 07-18-2007 09:52 AM
SteelHorse rear stands Wombat Gear & Gadgets 2 06-08-2007 09:12 PM
Anyone using these ebay rear stands? bikeman Speed Triple Forum 14 07-10-2006 06:16 AM
Rear stands for the triple.. Desmo Speed Triple Forum 4 06-18-2006 01:52 PM
Rear stands Gazzer Speed Triple Forum 5 11-12-2004 07:36 AM
