Stalls at idle? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-17-2012, 10:37 AM   #1 (permalink)
Main Motorcycle: 2005 Speed Triple
Other Motorcycle: 2004 Speed Four
Extra Motorcycle: 2009 Kawasaki Versys
Stalls at idle?
I just got a 2005 S3 with about 10.5k miles. Basically stock (the only upgrade I found was different mirrors and a different front brake line).
I learned very quickly not to try to rev the engine when starting it, because the ECU freaks out. However, I'm still running into an issue where sometimes if I pull the clutch approaching a stop and drop from 3k-4k rpm down to idle, the bike just stalls. When I start it back up, it idles really low like 800rpm for about 5-10 seconds, then slowly the idle speed picks back up to normal. If I try to ride off while the idle is low like that, it will die again as soon as I pull in the clutch.
Any suggestions? Is my fuel map messed up, or maybe the throttle position?
2005 Speed Triple
2004 Speed Four
2009 Versys
1997 DR350SE
Jehos is offline   Reply With Quote
Old 07-17-2012, 12:52 PM   #2 (permalink)
Main Motorcycle: hinckley S3
have the exactly the same problem...
...throttle body synchronization was the cure.
Antihero is offline   Reply With Quote
Old 07-17-2012, 03:27 PM   #3 (permalink)
Ah, thanks. Is that a do-it-yourself kind of thing?
2005 Speed Triple
2004 Speed Four
2009 Versys
1997 DR350SE
Old 07-22-2012, 06:29 PM   #4 (permalink)
Main Motorcycle: 1999 S3
Had a similar problem on an older s3. I Blew on all the breather lines from the tank and it fixed the issue
andytrance is offline   Reply With Quote
Old 07-23-2012, 01:36 AM   #5 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
Start bike, do not touch throttle.
Open beer.
Let bike idle until the fan kicks in
Open another beer.
Wait until fan is on for a minimum of 12min..
This will reset the adaptives. See if that helps. I do suggest checking the airbox for any obstructions, mice nest, etc. As stated, checking the throttle body balance is also a good idea. You will need TuneECU and an OBD-2 cable for that.
edit: forgot to mention, if you give the throttle ANY input, ANY time you are trying to start the bike, it will make her bitchy..
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 07-23-2012, 04:09 PM   #6 (permalink)
Newbie
Main Motorcycle: speed triple 1050
Other Motorcycle: R,Enfield Lightning 535
Had this on a sprint rs - there is a sensor on the crank that tells the cpu if the engine is turning over or not - mine was dicky kept stalling or stopping at junctions - easy fix - well that was my prob anyway
Peter Howes is offline   Reply With Quote
Old 08-21-2012, 10:22 AM   #7 (permalink)
Main Motorcycle: '06 Speed Triple
Other Motorcycle: '80 Kawasaki KZ 750
Extra Motorcycle: '73 Yamaha TX650
Hey Jehos, I'm having the same problem on my bike. The shop I brought it to replaced the TPS and stepper motor, but its still doing it ($700 later). Did you happen to figure it out?
killcity is offline   Reply With Quote
Old 08-21-2012, 03:33 PM   #8 (permalink)
Main Motorcycle: 1998 T509 Speed Triple
triplerock's Avatar
Other Motorcycle: 1976 KZ900
Extra Motorcycle: 1980 KZ550
+1 on Joe's comment- Check air filter, could be something simple. Sounds like classic engine starving for air, aside from all the other technical stuff that could be causing it.
triplerock is offline   Reply With Quote
Old 08-21-2012, 04:19 PM   #9 (permalink)
it's weird, because it only happens to me when i have the bike in gear, rolling , then i pull in the clutch and let off the throttle. if i leave the bike in neutral, with the clutch left out and rev it, it comes back down to correct idle.
Old 08-21-2012, 05:09 PM   #10 (permalink)
Equito's Avatar
Other Motorcycle: '04 Concours
Extra Motorcycle: '01 ZRX, '98 VFR
You can read about my experience here: http://www.thespeedtriple.com/forum/...most-stop.html
Not to say my cause is your cause, but it's another data point for you.
Equito is online now   Reply With Quote
Stalls off idle GearHd6 ECM and FI Tuning - Help, Tips & Tricks 3 06-13-2011 03:34 AM
Unstable idle and stalls Greyboy Daytona Deliberations 15 08-16-2010 08:57 PM
New Bonnie stalls at idle...HELP!!! monks_point Twins Technical Talk 8 08-08-2009 10:25 PM
stalls, won't idle tgreco50 Classic, Vintage & Veteran 7 07-06-2008 05:48 PM
Trophy stalls out at idle. dogg Trophy 11 11-09-2005 04:44 PM
