rectifier/regulator - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-07-2012, 01:22 PM   #1 (permalink)
Main Motorcycle: triumph speed triple 1050
rectifier/regulator
Anybody know where i can purchase the upgrade kit for my speed triple 2005.
z900a4 is offline   Reply With Quote
Old 07-07-2012, 01:32 PM   #2 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
I purchased mine from this guy, I think he is a member here . great kit .
It installs just like the charging sticky reccomends , right to the battery.
DieselGeek is online now   Reply With Quote
Old 07-07-2012, 01:49 PM   #3 (permalink)
Thanks Diesel Geek just bought one.
Old 07-08-2012, 11:48 AM   #4 (permalink)
Main Motorcycle: SIII 1050 07'
mnhoulden's Avatar
DG,
Out of curiousity, did you bypass the connector from the stator to the R/R?
Cheers,
Mark
www.azdirtyaces.com Motomarathon, CO. 2010 ASMA #309 IBA#34978~ SS1000~ 10.11.08 B2B Insanity~ BB1500~ 10.17.10
Alaska Blog- http://3umphak.wordpress.com/
mnhoulden is offline   Reply With Quote
Old 07-08-2012, 01:09 PM   #5 (permalink)
DieselGeek's Avatar
Yes, I hard wired straight to the stator.
I cut the connector off and used the official Ford recommended solder joint with heat shrink cover.
I also terminated the power input to the harness and wired straight to the battery.
More / poor connections = more potential failure points. Eliminate them
Old 07-08-2012, 02:50 PM   #6 (permalink)
mnhoulden's Avatar
So then you can still test the stator off of the lead to the R/R. correct?
I did the upgrade ages ago but left the connectors in place, I did however upgrade to the Eastern Beaver weather proof connector so no hassles there.
Cheers,
Mark
Old 07-08-2012, 02:57 PM   #7 (permalink)
DieselGeek's Avatar
Yes that is correct.
It is a little more of a PITA to retest , but I tested the stator before I upgraded and I am just hoping all is well right now .
At the time I upgraded I did not have the patience to wait for the EB parts .
Old 07-10-2012, 09:19 AM   #8 (permalink)
Hi,DG have not got it yet on its way from america but will let everyone know after i install it,diagram on installing comes with it so will let you know.
Old 07-11-2012, 02:55 AM   #9 (permalink)
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
Originally Posted by DieselGeek View Post
At the time I upgraded I did not have the patience to wait for the EB parts.
I just ordered some waterproof connectors and a few fuse holders from him. I had my order "expedited" through the Japanese post. It was in my hands, from Japan, to Alabama, in two days, for $12
USPS is seriously dropping the ball, they need to take some notes..
SUPPORT THE TROOPS!!
Joe Houle is offline   Reply With Quote
Old 07-11-2012, 03:00 AM   #10 (permalink)
Joe Houle's Avatar
FYI, I'm currently replacing the fuse older that comes in this kit, its junk. It builds up too much heat the the black plastic part melted/warped. I caught it during normal checks on the bike. The fuse was NOT blown. I went with the fuse holders eastern beaver carries. They keep both wires coming in fully separated, and the housing allows plenty of cooling vs the supplied thick black plastic one that retains it.
regulator rectifier thap8riot Sprint Forum 4 11-25-2011 10:48 AM
Regulator AND Rectifier FifeTiger Tiger Workshop (archive) 1 10-09-2009 10:05 AM
regulator rectifier help evalu8or Twins Technical Talk 15 07-10-2009 09:03 PM
Regulator / Rectifier help Erickex Daytona Deliberations 12 06-16-2009 09:44 PM
Rectifier/Regulator bratpane Triumph SuperSports 3 08-18-2006 05:43 AM
