I just got my bike back from the dealer. The mechanic pinched the breather hose under the tank and it stopped running. I did find quite a vacuum in the tank when i discovered it. Now it will crank and crank but nothing. after 20 to 30 seconds of cranking 1 puff but still nothing. Called the service department and they have no idea why it wouldn't run. Has anyone had a similar problem? I would like to fix myself if it is an easy fix.( they took 3 weeks to do the coolant hose recall, replace the passenger peg hangers, and work on the brakes) So I don't want to take it back unless absolutely necessary. I am also not sure that I trust them since this problem occurred after 2 minutes of idling, so they most likely didn't test ride it after servicing.
Thanks
