Another oil leak thread - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
post #21 of 30 (permalink) Old 09-17-2012, 07:58 PM
Main Motorcycle: 2011 S3
Originally Posted by djn876 View Post
How loose were they out of curiosity? Just make sure you didn't over-tighten them and squeeze that gasket down too much or it will continue to leak.
Loose enough that I could clearly see where the oil was seeping in several spots. All I did was kinda "snug" them tight. 1/4 to 1/2 a turn maybe.
Again, not a real big deal, but kinda a surprise. I had numerous oil spots along the inside of my bellypan which was hiding the issue until enough built up to drip onto the garage floor.
Damascus is offline
post #22 of 30 (permalink) Old 09-17-2012, 08:03 PM
Originally Posted by Ebster1085 View Post
Well, there ya go! I really have read a lot of threads about these particular bolts being loose on the 11 models. Very strange if you ask me, but certainly something good to know.
Nope - not your imagination and thanks for pointing it out. Not too surprising to have a few hiccups with any new model year, but I thought the motor was pretty much unchanged from years past.
Maybe Triumph changed bolt suppliers? Sold their torque wrenches for extra cash? I dunno.
Damascus is offline
post #23 of 30 (permalink) Old 09-17-2012, 09:08 PM
Main Motorcycle: All of them
Ssmithcreative's Avatar
Other Motorcycle: 2000 SV650
Extra Motorcycle: 1972 CB350f
Had the same issue on my 09, so I guess it carried over to the 11.
Ssmithcreative is offline
post #24 of 30 (permalink) Old 09-18-2012, 07:03 AM
Main Motorcycle: 2011 Speed Triple
Other Motorcycle: Ninja 300
^ It is pretty much the same engine. And even properly torqued bolts from the factory will loosen up, that's why it is a good practice to check and retorque after the first couple hundred miles, and then again periodically. Stuff loosens up over time, it's not Triumph specific.
djn876 is offline
post #25 of 30 (permalink) Old 09-18-2012, 12:47 PM
You're telling me?
My middle-aged body is loosening up! And not in a good way.
It's just that this is the first of 10 bikes to do so to this extent. But no biggie, and I'm on hands-on guy anway. Adds to the character of this little Spitfire.
Damascus is offline
post #26 of 30 (permalink) Old 09-18-2012, 02:56 PM
^ This made me laugh. And yeah, I just meant cars, trucks, whatever, its always a good idea to give it a once over as things loosen up from metal expansion and contraction, etc., but it sucks to have it happen on a newer machine that you'd hope to be trouble free for at least a few years.
djn876 is offline
post #27 of 30 (permalink) Old 11-04-2012, 07:35 PM
Main Motorcycle: '09 Triumph Speed Triple
clamacious's Avatar
Other Motorcycle: '13 KTM 250 XC-W
Extra Motorcycle: '14 Aprilia Tuono
Another vote for checking your oil pan bolts. My '09 developed a minor leak this year and I thought it was probably just weeping from the oil filter and I'd get it this fall when I did the oil change/winterizing ritual. When I got down to spin off the drain plug I saw that one of the bolts had completely backed off and was resting on the exhaust header. All the other bolts were in various states of barely beyond finger tight. Yikes!
I'll be checking them with each oil change from now on. Seems to be a common issue.
clamacious is offline
post #28 of 30 (permalink) Old 11-04-2012, 08:53 PM
Main Motorcycle: '08 S3
Joe Houle's Avatar
Other Motorcycle: '02 S4
Extra Motorcycle: '08 Scrambler
I lost a few from the S4 in the same fashion
SUPPORT THE TROOPS!!
Joe Houle is offline
post #29 of 30 (permalink) Old 11-05-2012, 01:39 AM
Main Motorcycle: Triumph Trophy 3
FoothillRyder's Avatar
Other Motorcycle: '98 Triumph Tiger
Extra Motorcycle: '96 Triumph Sprint
I would think it might be worth using some thread locking compound, no?
- FoothillRyder
AMA# 289558, COP#0001, BIR#47
'97 Trophy 3, '98 Tiger, '96 Sprint
My Blog
FoothillRyder is offline
post #30 of 30 (permalink) Old 11-05-2012, 07:25 AM
Main Motorcycle: 2007 Triumph Speed Triple
Ebster1085's Avatar
Send a message via AIM to Ebster1085
You guys using some blue loctite when you retorque, or is that not advisable?
LSL Damper OES Sliders Sunline Shifter MIVV CF Slip On K&N Air Filter FH012AA R/R Stoltec Starter Cables The2Wheels Levers Rick's Hotshot Stator Samco Hoses RK Chain & Sprockets
Ebster1085 is offline
Yet another oil leak thread - Scrambler Drifter Dave Air Cooled Twins Technical Talk 9 08-03-2010 02:57 PM
oil leak, stripped thread advice please Andy-Brad Triumph SuperSports 5 04-30-2010 11:07 AM
The Consolidated Coolant Leak Thread Diego Street Triple Forum 62 10-08-2009 08:48 AM
Another Oil Leak Thread. Sorry! Mitch67 Air Cooled Twins Technical Talk 9 08-07-2008 08:47 PM
I just wanted to start a new thread so that Benzos thread doesn't keep getting pushed to the top of graciejohn2 Speed Triple Forum 2 11-29-2006 01:47 PM
