That "Huge Opening" you see is for the fuel pump and cover. The fuel pump is attached to this cover, inside the tank. There are only a few things to connect to the tank. The two breather lines (don't put them on backwards!), the fuel pump electrical plug, and the fuel line quick disconnect. The last two items are part of the fuel pump plate that bolts to the bottom of the tank.
It's relatively simple to remove the tank, but I think it's silly that they didn't make it easy just to tip the tank up for access to the air box. It would have been so easy! But no, you have to remove the tank completely.
When removing the tank I found it was a good idea to completely take off the rear body work. It's not that hard, and it makes life a lot easier. Particularly the left side bodywork, because you'll need to get in there to remove and reattach the breather hoses.
The fuel quick disconnect makes taking the tank off almost a joy. Just pull it apart. Afterwards, check to make sure the rubber o-rings are still in good shape, or when you put it back together it may leak.
