WAIT! Before you replace any female connectors check your O-rings! I got a nice little section of one of mine chopped when reconnecting fittings and ended up with a nice leak of my own. All I had to do was replace the O-ring and the leak was fixed. The rings are black so you'll have to dry them off and look closely to see if there are any cuts, nicks, or chunks missing.
O-rings can be found at any Autozone or similar auto parts emporium.
The male connectors should be one solid stainless piece with the hose clamped onto it and, at least mine, has two O-rings per connector.
