On 2005-11-28 16:52, SprinklerHead wrote:
Geof3
I brake with two fingers, always have. When I have the brake lever hitting my other two fingers, I consider that excessive travel. That's while riding, not while sitting still.
That's silly, do you really think Triumph cares about your riding style? I learned four on the track and occasionally use two, If I need to break REALLY hard two doesn't do it. Four is not an issue.
So, if the problem is all about a riding style, then good luck getting any love from Triumph. There is a HUGE thread discussing this ad-nuasium over on t595. The 5/8 MC is a quicky "fix" at best.
Anyway... things are the way the are, until my bike quits stopping when I want it too, I'm good to go.
I agree that if the problem is progressively worsening than it IS a problem... But that would indicate a bad master or other bleeding/air issue... the calipers can only go so far. Somewhere the pressure is being lost...
Good luck ya all!!
[ This message was edited by: Geof3 on 2005-11-28 18:27 ]
