brake resevoir brackets?? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-15-2012, 11:16 PM   #1 (permalink)
Main Motorcycle: 2011 speed triple
i just got new triumph brake resevoirs for my 2011 sp3. and to my surprise there is no brackets for them, anyone know where i can buy that bracket in the picture and also the rear looks like it mounts backwards, whats up w that??http://www.pure-triumph.com/images/p...-Reservoir.jpg
Bguag47 is offline   Reply With Quote
Old 04-16-2012, 12:08 AM   #2 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
The picture you linked to is the reservoir for the 2010 and older .
This is the 2010 and older
this is the 2011 and up
When I mounted the 2011 + to my 06 I had to make a custom bracket.
Looks like the dealer sold you the wrong unit. The swap should have been straight across.
DieselGeek is online now   Reply With Quote
Old 04-16-2012, 10:49 AM   #3 (permalink)
Thanks, id say we should trade but I destroyed my old bracket making a new one. I guess as long as its mounted somewhat level its all good, although the angled hose connector would work better on my bike
Old 04-16-2012, 06:59 PM   #4 (permalink)
Main Motorcycle: Speed Triple
Marco's Avatar
Other Motorcycle: XT500 in pieces
Probably shouldn't be too creative with your brakes though...
MY2011 S3 - Evotech-Performance, Top Block Racing, GSG, Arrows, Triumph, Tune-Ecu, TechSpec, Valter Moto.
Marco is offline   Reply With Quote
Old 04-16-2012, 07:24 PM   #5 (permalink)
DieselGeek's Avatar
I made my bracket out of a 6mm wrench , bent it with a torch , powdercoated it and stuck it on . Should be no problems .
Old 04-17-2012, 12:46 AM   #6 (permalink)
Main Motorcycle: 06 Speed Triple
Delan's Avatar
Other Motorcycle: Vespa PX
Extra Motorcycle: Aprilia RS250
I got one of these Rizoma mounts... might work for you..
http://www.pjsparts.com/catalog/prod...roducts_id=632
Cheers, Delan
Delan is offline   Reply With Quote
Old 04-17-2012, 07:11 PM   #7 (permalink)
delan- could u post a picture of yours mounted? thanks
Old 04-18-2012, 01:02 AM   #8 (permalink)
Delan's Avatar
sure.. i'll get one for you by tomorrow.
Cheers, Delan
Old 04-18-2012, 08:58 PM   #9 (permalink)
Delan's Avatar
as promised.
Sorry I don't know how to set orientation on attachments as they view the right way up on my PC.
Also you need to reverse the connection for the speed as the mirror plug bolt is too fat to fit into the thinner section which I now have fitted to the bottom of my resevoir.
brake resevoir brackets??-img_0751-1-.jpg   brake resevoir brackets??-img_0755-1-.jpg
Cheers, Delan
Last edited by DieselGeek; 04-18-2012 at 09:38 PM. Reason: forgot to add detail / DG expand pics
Old 04-18-2012, 09:31 PM   #10 (permalink)
Thanks for the pics but I hav the 2010 and older triumph resevoir and not sure if that mount will fit with the sideways mounting tab my resevoir has
Brake resevoir SE Bonnie Rose Twins Talk 5 08-31-2009 03:05 PM
Leak at Brake Resevoir Cap BonneRider Twins Technical Talk 7 04-20-2008 07:58 PM
brake resevoir Rocky Twins Technical Talk 7 04-10-2008 11:07 AM
Thruxton Brake resevoir Anne Twins Talk 6 02-26-2007 02:25 PM
Rizoma brake resevoir nissn1 Speed Triple Forum 4 12-27-2005 02:37 AM
