brake resevoir brackets?? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old 04-18-2012, 11:06 PM   #11 (permalink)
Main Motorcycle: 06 Speed Triple
Delan's Avatar
Other Motorcycle: Vespa PX
Extra Motorcycle: Aprilia RS250
Originally Posted by Bguag47 View Post
Thanks for the pics but I hav the 2010 and older triumph resevoir and not sure if that mount will fit with the sideways mounting tab my resevoir has
You should be able to use the larger diameter hole under the pinch bolt (a bit like deiselgeek has done with the spanner) and that sets the orientation sideways for you resevoir braket.. I think it functionally would work personally. But you might have some distance issues with the mastercylinder and the resevoir.. and as a result I think it might look odd.
Cheers, Delan
Delan is offline   Reply With Quote
Old 04-18-2012, 11:16 PM   #12 (permalink)
SUPER Line-X'd Moderator
Main Motorcycle: 2006 Speed Triple
DieselGeek's Avatar
If you look at the pictures in the Rizoma instructions the mount allows for the side mount position.
DieselGeek is online now   Reply With Quote
Old 11-18-2012, 12:37 AM   #13 (permalink)
Main Motorcycle: Thruxton
I had an hour spare this arvo so I knocked this up for the Thruxton out of some 3 mm flat alu.
It looks like this on the bike. Lower & out of the way.
Timinoz is offline   Reply With Quote
Brake resevoir SE Bonnie Rose Twins Talk 5 08-31-2009 03:05 PM
Leak at Brake Resevoir Cap BonneRider Twins Technical Talk 7 04-20-2008 07:58 PM
brake resevoir Rocky Twins Technical Talk 7 04-10-2008 11:07 AM
Thruxton Brake resevoir Anne Twins Talk 6 02-26-2007 02:25 PM
Rizoma brake resevoir nissn1 Speed Triple Forum 4 12-27-2005 02:37 AM
