BikeBandit
Old 11-20-2005   #1 (permalink)
Okay, my chain is very loose. I tried to adjust the chain, but I cant move the thing anymore. Is there a limit that the little adjustment thingy wont move anymore? Or am i not doing it the right way? I can loosen the chain, but cannot tighten anymore.
I probably need a new chain, so I might just get another chain and sprockets, and go 1 down on the front, and 1 up in the rear for street riding.
http://www.lusori.com
Cement/stone/brick work in DC/MD/VA
http://www.cycleposers.com
forum for motorcycle idiots, retards and morons
roadkill is offline   Reply With Quote
Old 11-20-2005   #2 (permalink)
Sounds like you need a new chain.
02S3 is offline   Reply With Quote
Old 11-21-2005   #3 (permalink)
Favorite Bike: '01 Speed Triple
I think your gearing is 18/43 stock. If you go to a 45 T on the rear, you will love it. I did that, and added a 19 T, but have the 18 to use if I want. I got a DID 530 XM , 110 links.
Speed3 is offline   Reply With Quote
Old 11-21-2005   #4 (permalink)
hey speed3, I don't understand your gearing choice.... Is that not almost a complete washout by increasing the rear by 2 teeth(acceleration) and increasing the front by 1 tooth(top end)??? Sorry, I just don't understand how you can tell much of a difference. If anything, I would think you're geared a little higher, not lower.
cheapbastard is offline   Reply With Quote
Old 11-21-2005   #5 (permalink)
so, anyone know if there is a limit on how much you can adjust the chain?
I will probably do the 18/45 combo.
Old 11-22-2005   #6 (permalink)
I went to 18/45 because everyone said how great it is, and I thought the stock gearing was too high. I liked it around town, but put the 19 on for trips and left it. It is a bit lower ratio than stock, but the cool thing is, I can throw the 18 back on with a chain adjustment. The reason I didn't go with a 17 is the accelerated wear of the rubber S/A protector that people reported.
how much slack for the chain? redl1nerpm Triumph SuperSports 12 08-07-2007 11:12 AM
Chain adjustment/slack Trotts Tiger Workshop 7 08-02-2007 03:00 AM
chain slack ricster Sprint Forum 9 05-09-2007 10:45 AM
Chain Slack frizbee_dog Sprint Forum 5 10-14-2004 02:13 AM
