AdvanstarMotorcycleShowsShopTriumph.comSpringfield ArmoryMotorcycle.com Classifieds!Motorcycle.comBikeBanditTrident-Exhausts.comSportbikeTrackGearRacerPartsWholesale
Old 11-14-2005   #1 (permalink)
Just did the 12000 mile valve adjustment on my '03. One intake was tight so when I pulled the cam I found that the cam end bearing (outboard of the timing chain) was significantly galled. The lower half of this bearing is the head itself and to fix it requires a new head.
I don't know how serious this is as the inner cam bearings are fine.
Anybody else had this issue?
Any thoughts?
PhilM is offline   Reply With Quote
Old 11-15-2005   #2 (permalink)
Doesn't sound too good. If it was me i wouldn't run it like that. If you can't find a used head I wonder what the best fix would be. Maybe boring that one bearing and coating the journal back for the right clearance. I'd think you'd want to do some disassembly to make sure there's no metal in the oil system.
littlefield is offline   Reply With Quote
Old 11-15-2005   #3 (permalink)
I've contacted Triumph, the bike is still under warantee.
bearing noise? mick-f Sprint Forum 6 07-22-2007 11:24 AM
Headstock bearing jnicosia Speed Triple Forum 1 05-01-2007 06:33 PM
cam gears and cam sprocket fbird Hinckley Classic Triples 7 08-19-2006 07:41 AM
Ruined Bearing RocketEd The Rocket Science Forum 1 07-10-2005 06:35 PM
Crankshaft bearing Osara Modifications & Workshop Talk 13 06-22-2004 03:16 PM
