Old 11-12-2005   #1 (permalink)
What is the inside diameter of the removable baffles for some aftermarket S3 1050 cans? Are they just some straight tubes that go inside the can? And finally, are they effective?
Thanks in advance.
HarriS is online now   Reply With Quote
Old 11-14-2005   #2 (permalink)
Senior Member - Site Sponsor
Ours are 10mm ID and yes they are effective - they take about 12 dB off but only 3 bhp less than the full race - most are just straight tubes
Regards
Peter Sorrell
Trident Exhausts
www.trident-exhausts.com
Triumph Only Exhaust Specialists
Wolf is offline   Reply With Quote
Old 11-14-2005   #3 (permalink)
Thanks! I did not imagine they are that small ID. I was planning some for my cans and I thought 22mm would be too small. I don“t know if I am going to use them but I think they are good to have around anyway.
The cans are 45mm ID straight perforated tube absorbtion type and pretty loud as such. The bike is winterized already so I have to wait few months to test it properly anyway.
Old 11-14-2005   #4 (permalink)
HarriS,
The staintune baffles have an inner diameter of 25mm.
John
I want to die peacefully in my sleep like my grandfather, not screaming
in terror like his passengers.
Legman is offline   Reply With Quote
Old 11-15-2005   #5 (permalink)
Dont forget with our baffles the gas flows through the 10mm holes but also around the sides of the tube too - it's about changing the flow speed more than blocking off the pipe with a smaller one
Regards
Peter Sorrell
Trident Exhausts
Old 12-11-2005   #6 (permalink)
I made two pairs of baffles. One is 24mm ID and the other 31mm. They cut the noise quite a bit.
The 24mm ones sound a bit like my drilled stock cans.
The 31mm is a bit louder but not overly so.
Without baffles it is just loud :-D .
I think the best compromise might be the 31mm ones since they do not choke much at all because they are only a bit smaller than the stock link pipes. I have to dyno all of them in spring and measure the decibels.
Any good pipes with removable baffles? ridesouth Twins Technical Talk 12 10-07-2007 06:16 PM
Staintune Reverse Cone Mufflers-Do they come with removable baffles? Motoleo Twins Technical Talk 14 11-07-2006 06:37 PM
Aftermarket Cans 03 S3 Windchill Speed Triple Forum 5 05-18-2005 08:39 PM
Removable baffles from CF-Hi Mount exhaust? Ghost-Rider Speed Triple Forum 6 05-18-2005 04:15 PM
Aftermarket Cans paulie Tiger Chat 2 07-22-2004 06:16 PM
