Ouch, thats a sign of a ruptured blinker fluid reservoir. You'll have to take off your rear subframe, fuel tank, both tires, and your oil pan to get to it.
Lol, actually, it sounds like you jarred a ground somewhere. Check your battery terminals and connections just in case something is a hair loose. The first sign of a loose ground is your headlights going dim or off, then your speedo reading zero, and also your motor sputtering at times. These are also the signs of a crapped out battery.
