Trident-Exhausts.comMotorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!ShopTriumph.comRacerPartsWholesaleBikeBanditSpringfield Armory
RacerPartsWholesale
Old 10-31-2005   #1 (permalink)
The DPO told me he just changed the coolant and the oil on the bike. I am having problems with the coolant overflowing out of the reservoir. I have two questions...one where is the pressure cap and two how to I properly change the coolant. It looks like this bike might be prone to getting air lock in the cooling system. Oh and one more thing. What type of coolant should I use in the bike? Anything special or any aluminum compatible stuff?
Chris: Dad, what\'s the blow-hole for?
Peter: I\'ll tell you what it\'s not for, son. And when I do, you\'ll understand why I can never go back to Sea World.
"Bloody hell. Believe that, and you'll believe we Brits aquired our empire to bring civili
AlucardIdraculA is offline   Reply With Quote
Old 10-31-2005   #2 (permalink)
The cap is under the front gas tank cover. Remove the cover and it sits below. As for coolant the triumph shop should carry proper coolant.
SlvrSurfr is offline   Reply With Quote
Old 10-31-2005   #3 (permalink)
I also have a 2000 s3. Had the same prob., Mine kept overheating, took it to the dealer and they did not fix it. Turned out the thermostat went bad, i replaced it, and voila.
I just use regular honda coolant.
http://www.lusori.com
Cement/stone/brick work in DC/MD/VA
http://www.cycleposers.com
forum for motorcycle idiots, retards and morons
roadkill is offline   Reply With Quote
900 coolant issues lobo10s Trophy 4 06-24-2008 08:27 PM
Coolant Change 2000 955i Help lornegibbons@ntlworld.com Daytona Deliberations 2 02-10-2008 09:37 PM
Bike Starting Issues twlynch Classic, Vintage & Veteran 20 04-11-2007 10:32 AM
Used bike purchase - brake woes Sprint Forum 6 09-18-2004 09:32 PM
Bike Coolant LegendGirl Modifications & Workshop Talk 1 04-24-2003 10:24 AM
