Best $46 or 367$ mod...45T rear sprocket! - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 348 (permalink) Old 12-18-2011, 01:28 AM Thread Starter
Main Motorcycle: 2007 Speed Triple
Other Motorcycle: 1999 VFR800--retired
Installed the 45T sprocket today.....best mod for the $($46 from Sprocket center). I was going to do a full 520 conversion, but couldn't justify $220 when my chain was in perfectly good condition. $46, however, was a no brainer. Didn't have to break the chain or remove the wheel. She now pulls like a beast...especially in lower gears. It's a must do!
Will
lospice1 is offline
post #2 of 348 (permalink) Old 12-18-2011, 03:32 AM
Main Motorcycle: 2011 Speed Triple
Other Motorcycle: Honda XR 250R
Any idea how this mod affects the speedo? How far off will it be?
Does anyone know what tooth sprocket the 2011 has in the rear? My bike is an hour away in storage.
Odoa3 is offline
post #3 of 348 (permalink) Old 12-18-2011, 10:37 AM
Main Motorcycle: 06 S3
noobinacan's Avatar
Other Motorcycle: cbr600rr
ha ..sweeet dude.
Like been saying for a while, with stock rear sprocket, you're cheating yourself.
unless you're doing a LOT of touring and highway miles. stock sprocket makes sense, but if you're setup for the city, throw a 46 tooth on the rear
noobinacan is offline
post #4 of 348 (permalink) Old 12-18-2011, 01:23 PM
Main Motorcycle: 2005 Speed Triple
Other Motorcycle: 2008 Street Triple R
Get yourself a 15 dollar OBDII cable and hook up your speedy to your laptop, you can correct the speedo of your speedy for free.
Fortuna Favet Fatuis
LoSBoL is offline
post #5 of 348 (permalink) Old 12-18-2011, 01:29 PM
Main Motorcycle: My Red Speed Triple SE
Tire Torcher's Avatar
Other Motorcycle: 2009 Speed Triple Black
I agree, it's a must do. 45T rocks.
Tire Torcher is offline
post #6 of 348 (permalink) Old 12-18-2011, 03:20 PM
Main Motorcycle: Early 2007 Speed Triple
DarlingRat's Avatar
Originally Posted by noobinacan View Post
unless you're doing a LOT of touring and highway miles.....
What about 50% twisties and 50% cruising on highways. Would it be worth it to go for the 45 then?
DarlingRat is offline
post #7 of 348 (permalink) Old 12-18-2011, 03:43 PM
Main Motorcycle: 2006 Speed Triple GT
SUPERcharged Moderator
DieselGeek's Avatar
Extra Motorcycle: 2012 SV650S
Yes the 45T is a great mod , you will not see a significant loss of mpg . I do 70% highway 30% city , no problems . I probably lost 10-20 kms a tank. But that is mostly due to the "need" to wack the throttle open at every opportunity and pass / accelerate like a boss all the time.
Combined with the quick throttle mod .... whoopee!!
The speedo correction can not be done with a code scanner . You will need to download the freeware TuneECU and get a 20$ ( or less) ebay vag-Com cable to make your speedo corrections .
DieselGeek is offline
post #8 of 348 (permalink) Old 12-18-2011, 04:32 PM
Main Motorcycle: '11 Speed Triple
Dynastyss's Avatar
Other Motorcycle: Buell XB9SX
I am intrigued!
How easy is the install? What is involved?
Dynastyss is offline
post #9 of 348 (permalink) Old 12-18-2011, 04:40 PM
DieselGeek's Avatar
On my 2006 I put the bike on the stand ( my stand is reverseable so I can pick up from the tire side or the chain side ) adjusted the chain slack to the max. Then I unbolted the factory sprocket .
I puled the old sprocket off, put the new sprocket into the slack chain and lined up the bolts , torque to spec and adjust the chain tension. torque the pinch bolt and test ride .
If you have all the tools at hand its a 15 min job.
post #10 of 348 (permalink) Old 12-18-2011, 05:41 PM
noobinacan's Avatar
As a rule of thumb for myself...on Highway for cruise I don't go over 6k rpm. But if you're doing 50/50 street and twisty, 45 or 46 should not be a problem.
Here's the tool I used:
at 18F/46R I'm doing 92mph @6k.
http://www.gearingcommander.com/
is there a link for the tutorial on this ?
I haven't bothered to fix mine, but since its that easy, would like to..
Rear Sprocket uk955i Daytona Deliberations 3 07-28-2010 02:17 PM
Rear Sprocket kdowell Sprint Forum 5 09-05-2006 09:14 PM
rear sprocket colthrux Club Cafe' 3 04-02-2005 10:50 PM
Rear sprocket Tiger Chat 0 04-07-2004 05:50 AM
