Best $46 mod...45T rear sprocket! - Page 30 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-05-2012, 11:22 AM   #291 (permalink)
Main Motorcycle: 2012 Triumph Speed Triple
bradvanhorn's Avatar
Other Motorcycle: 2009 Kawasaki ZX-6R
Extra Motorcycle: 2012 Kawasaki Ninja 250
Originally Posted by fennell View Post
Its slightly better than stock, and yes it can wheelie more but all humans have a handy wheelie control device on the end of their right arms Its still too tall with 18/45 imo.
The bike feels flat and boring to me with the stock gearing, the 17/43 (very similar to 18/45) was a little better, but still didn't feel like a thousand should, i was still disappointed in the difference from the 675.
Now with 17/45 it actually has proper punch like a big bike should.
Hmmm, I'm going to try a 45 rear (+2) first. I'm interested in trying the 520 conversion (to help the weight loss program) but I definitely won't do that until I've sorted the sprocket size preferences.
bradvanhorn is offline   Reply With Quote
Old 12-05-2012, 04:21 PM   #292 (permalink)
Main Motorcycle: 2003 Speed triple 955i
Other Motorcycle: 1989 Honda CB-1 CB400F
Where is a good US source for a afam or renthal aluminum 44t rear sprocket? Thanks, Andy
lxtoploader is offline   Reply With Quote
Old 02-10-2013, 11:17 PM   #293 (permalink)
Well I've enjoyed reading this thread instead of doing work all morning. I was hoping to sanity check what I'm now planning to do...
Running an '07 S3, the chain and sprockets are well past their time so I'm thinking I move to a 18T (stock) front and 43T rear (which is stock for the later model S3's anyway). So this way I'm moving to "current standards". I also am not interested in having the wheel pop up on a whim in 1st and 2nd... a touch more pull (whether I notice it or not) moving from 42 to 43 will be enough for me.
Variables I can't account for are...
- The stock '07 chain is 106 links, so if I move from a 42T to a 43T is there a way to know what length I'll need?
- The later model S3's with the 43T also have a 190 profile rear tyre I think... I believe mine's 180... is having the 180 going to factor into the chain length I need?
- If the speedo is around about 6% high at stock, me moving to a 43T probably doesn't justify messing with the speedo calibration at all... my speedo will still be, what, 3-4% above actual speed... my odo will be a teeny bit off, showing less km's than I've actually done, but only slightly... is that correct?
I think I'll go with a 520 conversion too... not expecting any great change from it, but it sounds like a positive move and with the quality of chain/sprocket I'll get (DID, steel teeth etc) I don't expect I'll have any premature wear issues.....................
Thank You
Herbus is offline   Reply With Quote
Old 02-11-2013, 03:28 AM   #294 (permalink)
Legend
DEcosse's Avatar
Originally Posted by Herbus View Post
...The stock '07 chain is 106 links, so if I move from a 42T to a 43T is there a way to know what length I'll need?
A general rule of thumb is 4 extra teeth, fit 2 links (you must fit links in pairs)
Simple way to think about it is that if sprocket has four extra teeth, the chain goes around approx 1/2 of the circumference on the sprocket, so in this case two extra teeth or two links.
For one extra tooth, you would need 1/2 a link's pitch in actual length - moot - std 106 will be fine
(I actually helped friend fit 45 to std 106 chain - it was close to the limit of adjustment but in spec - if changing chain also, definitely go +2 links)
No
You're counting wrong way - going to larger rear sprocket than stock makes error worse, not better.
Old 02-11-2013, 03:29 AM   #295 (permalink)
Main Motorcycle: 2010 Speed Triple
SpeedJunkie1050's Avatar
Other Motorcycle: 2000 Honda Hornet 600
Herbus, if you're going +1 on the back you shouldn't need any more links if you buy a new chain.
Can anybody tell me whether a 108 link chain would be suitable for a +3 rear sprocket before i order it? (or should i be going for a 110 bearing in mind how much slack these S3's like?)
EDIT: DEcosse, you're good! Answering my question before i've even asked it! Thanks!
SpeedJunkie1050 is offline   Reply With Quote
Old 02-11-2013, 03:58 PM   #296 (permalink)
Main Motorcycle: 2011 Speed Triple
Ben_'s Avatar
Can confirm a 46T will not fit with standard chain; at least 2 extra links needed.
Ben_ is offline   Reply With Quote
Old 02-11-2013, 04:14 PM   #297 (permalink)
Main Motorcycle: speed triple 1050 2007
Hi, if you dont want the front wheel to come up, why not fit a 19 front sprocket and a 42 on the rear, it drops the revs by 600 in top gear for motorway riding , i tryed it when i had a few long trips to do,, then went back to 18/45 to use around town,
outlaw is offline   Reply With Quote
Old 02-11-2013, 07:03 PM   #298 (permalink)
Tal
Main Motorcycle: 2012 Speed Triple R
Did the upgrade today..can't wait for warm weather..
Tal is offline   Reply With Quote
Old 02-12-2013, 01:09 PM   #299 (permalink)
I prefer -1 in on the front sprocket. Does anyone feel that does not accomplish the same thing?
notowman is offline   Reply With Quote
Old 02-12-2013, 01:51 PM   #300 (permalink)
Main Motorcycle: '07 S3
oldrnslwr's Avatar
I went -1 on the front also. $23 and 10 minutes, nice change. I didn't read all 30 pages of this thread, but it works for me. No clearance issues at all.
'09 C14, '07 S3, '06 TTR 50
oldrnslwr is offline   Reply With Quote
Rear Sprocket uk955i Daytona Deliberations 3 07-28-2010 02:17 PM
Rear Sprocket kdowell Sprint Forum 5 09-05-2006 09:14 PM
rear sprocket colthrux Club Cafe' 3 04-02-2005 10:50 PM
Rear sprocket Tiger Chat 0 04-07-2004 05:50 AM
