Edit
After doing a little research I was unable to confirm the following. However, I do remember reading that the new 1050 Speed Triple had a "Back Torque Limiter back when the model was announced. I think this was a mistake based on the fact that the bike unequivocally does have a Clutch Backlash Eliminator Gear- not the same thing at all.
None of my saved articles, brochures, or current web sites mention a slipper clutch or a Back Torque Limiter. But I'm leaving the following posted because it's essentially correct, other than it's wrong about the S3. :razz: :razz:
The 05/06 Speed Triples certainly do have what they call a "Back torque limiter" that is essentially a slipper clutch. One of the first mainstream bikes to have one. This was in all the S3 press releases and early magazine articles. However, it is not mentioned on the Triumph web site. It wasn't one of the main selling features.
The confusion here is a misconception of what it does and how it is constructed. The key word is "Limiter." This device limits back torque on down shifts, which makes it more difficult to slide the rear tire on downshifts. With a bike like the S3 that has tons of torque you need this.
Basically the way it works is on the back of the clutch basket is a ratchet device that allows the clutch to positively engage the teeth when the torque is in the normal direction, but when there is back torque the teeth slide against each other under pressure from a spring. The effect is like a secondary clutch that only works under reverse spin. If your back tire has less grip than the back torque limiter then it will slide, if the limiter has less grip it will slip. The limiter will never allow your clutch basket to free spin under these circumstances, as this would be dangerous.
However, this doesn't stop you from being foolish. If you downshift from 4th to 1st at 60 mph you are going to slide the tire, no question. The back torque limiter can't handle this amount of abuse.
I hope this clears things up.
[ This message was edited by: crashmasterd on 2005-10-27 21:08 ]
