SportbikeTrackGearMotorcycle.com Classifieds!BikeBanditShopTriumph.comRacerPartsWholesaleMotorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 10-23-2005   #1 (permalink)
Can any dealer mount and balance a rear? Are there any Triumph -specific parts or tools that are helpful or necessary?
Many thanks,
2cats
How do you like my new avatar? It's the "Aprilia" badge on my side bag - the one that fell off and can't be replaced.
2cats is offline   Reply With Quote
Old 10-24-2005   #2 (permalink)
Favorite Bike: '04 Speed Triple
Other Motorcycle: '02 Honda crf450r
Pretty much any dealer can change a tire. For me, I always remove the wheels and bring them into the dealer rather than the whole bike...........usually saves a little on labor costs. I don't think there are any special tools required, at least there arn't on my '04.
"Nekkid Aggression rules"
ken750f is offline   Reply With Quote
Old 10-24-2005   #3 (permalink)
The 2 dealers I have went to that were not triumph dealers had to go and buy a socket to fit the rear axle.
other than that thats about it. the first place I brought ot to used a BIG cresent wrench.
if I had a front stand I would just bring the Wheel down... no alignment or anything needed to mount the rear.
DaffyDuc is offline   Reply With Quote
Old 10-24-2005   #4 (permalink)
I have removed the rear wheel, using a rear stand. DaffyDuc, I'm assuming the socket your two dealers had to purchase is the same one I have purchased and have used to remove my rear wheel. I'm also assuming that you meant a rear stand, as opposed to a front stand.
Many thanks again,
2cats
Old 10-24-2005   #5 (permalink)
I just "strapped" my front end to the rafters in my garage to lift it off the ground and used my center stand for the rear. If you've got strong enough beams in your garage it works well!!!
Old 10-24-2005   #6 (permalink)
The only problem can be an adapter to balance the rear wheel (single-sided swingarm). I need a special one for my BMW, but I bought an excellent balancer that included it from Marc Parnes. About $100. Well worth it.
JC
\'03 BMW K1200RS
\'03 SV1000 naked
ELP_JC is offline   Reply With Quote
Old 10-24-2005   #7 (permalink)
Now that's the kind of thing that I've heard about, and I'm concerned about. Is there any way to know ahead of time if there will be a problem? Do the conical spacer, washers and crown nut come into play here at all (that is to say, should I bring them with me)?
2cats
Old 10-24-2005   #8 (permalink)
I just popped the bike up on the centerstand and took off my rear wheel myself after buying a socket for the job. I've got a buddy who works at the local Harley/Buell shop so he does all my dyno/wheel work for free, hehe.
Old 10-25-2005   #9 (permalink)
Well, the relatively close, highly regarded Honda dealer told me to defecate in my chapeaux and put it on. Probably didn't have the right adapter, they said.
2cats
Old 10-29-2005   #10 (permalink)
"I have removed the rear wheel, using a rear stand. DaffyDuc, I'm assuming the socket your two dealers had to purchase is the same one I have purchased and have used to remove my rear wheel. I'm also assuming that you meant a rear stand, as opposed to a front stand. "
Yes 2 different dealers did not have a large enough socket
and no I just tried the Front hanging from the rafters thing yesterday and It worked well. Thanks
rear tire... rockinokie Twins Technical Talk 4 08-20-2007 04:13 PM
Hagon rear shocks/150 rear tire ROBD Twins Technical Talk 12 02-09-2007 04:38 PM
50% of Factory Triumph Jackets NH Triumph Dealer SecondWindBMWT Speed Triple Forum 11 02-09-2007 11:59 AM
Triumph Jackets 50% off retail NH Triumph Dealer SecondWindBMWT Twins Talk 15 02-07-2007 09:47 AM
Triumph dealer can't change a Triumph tire redsled Speed Triple Forum 6 10-17-2005 10:08 PM
