Speed Triple isn't starting on first go.... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-25-2011, 05:31 AM   #1 (permalink)
Other Motorcycle: 08 Speed triple
Anyone know why its doing this??
Btw it does this only when its cold, ie mornings and when its been sitting for a few hours.
Also just popped in a shorai battery but it did it even with a normal battery.
dimlight is offline   Reply With Quote
Old 10-25-2011, 06:05 AM   #2 (permalink)
Main Motorcycle: 2011 Speed Triple
Reggub's Avatar
Thats very odd, as you have changed the battery I have no idea. I would start by measuring the voltage at the starter just in case you have some bad / high resistance wiring.
The first turn starts to circulate oil, but the starter stops due to the voltage drop
The second try it will start as the oil has lubricated the bores and cams reducing the effort needed to start.
Just a guess...
Reggub is offline   Reply With Quote
Old 10-25-2011, 06:13 AM   #3 (permalink)
But it is cranking a few turns
Old 10-25-2011, 07:28 AM   #4 (permalink)
Main Motorcycle: 2003 Speed Triple
PhilM's Avatar
Are you allowing the fuel system to build up pressure (3 seconds after you turn the key on) before you try to start it?
PhilM is offline   Reply With Quote
Old 10-25-2011, 08:01 AM   #5 (permalink)
yep i only start it after all sounds stop.
Old 10-25-2011, 09:15 AM   #6 (permalink)
mine started doing this,when its cold try jump starting it and see if its ok, i put an extra earth from batt to subframe and never had it happen again untill i took the earth strap off when i sold it,i rode it to the dealers to trade it in and they started it it did the same thing again hope this helps,also we did check the electrics and found nothing wrong
never thought i'd be on a triumph
eightfoot is offline   Reply With Quote
Old 10-25-2011, 11:27 AM   #7 (permalink)
Main Motorcycle: 2012 Triumph Speed Triple
Niqui's Avatar
Other Motorcycle: 2010 ZX-10R [Track Bike]
Have you tried letting the lights stay on for 30 seconds or so more after the fuel pump primes?
I know here with our nights hovering above 0 Degrees Celsius and when I don't ride for a couple days it won't start the first time if I try to just after it primes.
However always on the second try.
Now referring to what I said about waiting 30 seconds with the lights on. If I do that it starts every single time regardless.
Just a suggestion!
Niqui is offline   Reply With Quote
Old 10-25-2011, 01:31 PM   #8 (permalink)
Tim
Main Motorcycle: 07 SpeedTriple 1050w/MIVV
Tim's Avatar
Originally Posted by eightfoot View Post
...i put an extra earth from batt to subframe and never had it happen again ...
Interested in this idea.
Could you elaborate?
Why would this help?
Have a pic of it installed?
Tim
Tim is offline   Reply With Quote
Old 10-25-2011, 02:34 PM   #9 (permalink)
Main Motorcycle: 05 Speed Triple
Ferris's Avatar
My 05 does the same thing. Getting better now that the weather is warming and I'm using the 18A Shorai.
Perhaps something to do with the fact that the Shorai doesn't rest at 100% charge and always finds its way back to 90%. I'm on my third Shorai (2x14's + the 18) and I've also done the 4 gauge starter mod.
I also have a cheap, near new Chinese battery (Besco CTX12-BS), that also suffers the same. However, if I remove the smaller Yuasa from the Bonneville, it'll start first attempt?
Ferris is offline   Reply With Quote
Old 10-25-2011, 02:49 PM   #10 (permalink)
Main Motorcycle: '08 Speed Triple
ditchrat69's Avatar
Other Motorcycle: '06 Speed Four, '08 D675
Dimlight,
Do you have aftermarket levers? If so, try adjusting it so it is at it's furthest setting.
Also, try turning your handlebars to the right before start up....you might have some twisting/pinching in the starter wire
Ditch
ditchrat69 is online now   Reply With Quote
speed triple starting problem mag955i The Welcome Center 1 06-27-2010 11:55 AM
Speed Triple 06 starting problem mxd75 Speed Triple Forum 3 04-06-2010 05:46 AM
98 Speed Triple Starting Problem Sanders Speed Triple Forum 12 08-31-2009 01:43 PM
98 speed triple starting problems SP33D4 Speed Triple Forum 0 06-25-2009 03:37 PM
speed triple starting problem donlangan Speed Triple Forum 6 02-22-2009 09:33 AM
