On 2005-11-19 23:49, HiVel wrote:
My new sK sliders Item 116B are as follows: left side is 85mm alum hex.
The right side is a 50 mm alum hex with the black plastic parts being the same length approx 3" . The right side is inside the turn signal and the left side sticks out beyond the turn signal, The'06 bike has a steel guard bar on the right bottom below the radiator to protect it. They use M10 bolts and M12 washers and locking nuts. Nice set up it just looks odd. asymetrical if you will--
That size of hex bushings makes perfect sense for the pre 2005 Triples...if the 50mm aluminium hex was installed on the LHS of the bike (onto the engine mount which is attached to the outside of the frame) and the 85mm was installed on the RHS (onto the frame) then both sliders would stick out equidistant from the frame! Thanks for the info, I appreciate it.
By the by, SkyKings install instructions (PDF on his website) state that the aluminium hex bushings are both 70mm long, which is why I thought that his sliders would look odd with the LHS one sticking out 1 1/2" further.
