AdvanstarMotorcycleShowsMotorcycle.comTrident-Exhausts.com
Old 10-19-2005   #1 (permalink)
Hi all,
Anyone know whether the default 52mm Woodcraft clip-ons at the following link are at the proper angle for the 05/06 Triple? Are the bolts accessible?
http://www.woodcraft-cfm.com/Scripts...dproduct=17281
Also, do the CRG bar-end mirrors attach to these directly or do they require adapters? I asked Woodcraft and was told the inside diameter of the bars (5/8") but I'm not sure what this means for the mirrors.
Thanks,
ZM
zmann is offline   Reply With Quote
Old 10-19-2005   #2 (permalink)
Favorite Bike: 1996 Speed Triple
wiayeman's Avatar
Other Motorcycle: 2008 Speed Triple (matt)
Extra Motorcycle: 1970 Honda CT70
i just put skyking bar ends onto my harris clip ons. the i.d. of my bar tubes was meant to be 5/8, but the inserts were too large. john at skyking sent me some smaller ones and voila. i'm would hope that crg would do the same. if you haven't bought the mirrors yet, take a look at john's stuff on skykingproducts.com. good quality product and top bloke.
better dead than red
wiayeman is online now   Reply With Quote
Old 10-19-2005   #3 (permalink)
My last set of clip-ons hard a very small inner diameter so I just attached my CRG mirrors to the end of the bar. You'll have to move everything in about 1/4" though.
02S3 is offline   Reply With Quote
Old 10-20-2005   #4 (permalink)
check out this thread, this was part of a discusssion about a month or so ago. There are pics you can view to see how all worked out and issues to circumvent.
The '05-'06 triple fork width is 52mm, the Woodcraft bar ends are fitted with solid hard plastic and the CRG mirrors can go on the outside surface of the bar or you can use tools (hammer, drill, etc) to take the hard plastic end out of the bar ends, or purchase hollow bar ends from elsewhere (like LSL's for example which the CRG mirrors go into the ends without issue and do not require the adapter pieces that the stock triple bars use.
[ This message was edited by: rudebwoy85 on 2005-10-20 13:18 ]
rudebwoy85 is offline   Reply With Quote
Old 10-23-2005   #5 (permalink)
Thanks for the feedback.
ZM
Old 10-25-2005   #6 (permalink)
What are the other mirror otpions with clip ons that people have tried?
disco_is_dead is offline   Reply With Quote
Old 10-25-2005   #7 (permalink)
some people stick with the stock mirrors but put extenders on them. Should be able to find those at www.jacklilley.com,
just hunt around. Rizoma's and MV Agusta Bratale S mirrors have also been used by others.
Old 10-25-2005   #8 (permalink)
ES3
And of course Benelli TNT mirrors, watch the difference with original: :-D
No more Triumph
ES3 is offline   Reply With Quote
Old 10-25-2005   #9 (permalink)
Favorite Bike: 2004 S3--black
FelixLeiter's Avatar
Location: Where the oil comes from...no, not over there
If I mount a CRG folding bar end mirror to the end on the bar (not using an adapter) will the mirror still fold in all the way without hitting the bar slider? And/or will the CRG mirror mount onto the stock bar end plug/slider? I only want one mirror but don't want mis-matched bar end plugs.
Yr Fthfl Srvnt
FelixLeiter is offline   Reply With Quote
Old 10-26-2005   #10 (permalink)
aaronb_dsn's Avatar
i like my crg mirrors, they are a little low with the clip-ons on but the still work fine!
aaronb_dsn is offline   Reply With Quote
CRG Bar-End Mirror Help Wanted CoburnAndHughes Club Cafe 6 04-25-2007 01:09 PM
For those with CRG Bar End Mirrors... bluesock943 Club Cafe 8 09-26-2006 06:07 PM
Napoleon AP-104 OR CRG Hindsight Bar-End Mirrors aikojo Speed Triple Forum 7 04-28-2005 06:04 AM
Bar end weight/extension for CRG or Rizoma bar end mirrors? KAH24 Club Cafe 11 04-18-2005 05:33 PM
CRG Bar End Mirrors on S3 fwhite Speed Triple Forum 23 01-22-2005 12:41 PM
