I have the Triumph bag and it's a nice bag with lots of room. The main PIA is the mounting. It takes between 5-10 minutes to mount the pad. 5 minutes after you've done it a couple times, about 10 minutes the first couple. The first time you mount the pad, you have to mount two small, for lack of a better term, eyelets behind the gas tank. You have to remove the front seat to mount these and for that matter any time you mount the pad.
Once the pad is on it takes seconds to mount the bag, 4 QD buckles and off you go.
Hope this answers your question. I do like the bag quite a bit and it is very high quality construction.
[ This message was edited by: iscarian on 2005-10-17 21:23 ]
John
"What if the hokey pokey IS what it's all about?"
