ShopTriumph.comSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comTrident-Exhausts.comSpringfield ArmoryBikeBanditRacerPartsWholesale
Old 10-16-2005   #1 (permalink)
Had the new S3 for nearly a week now and we are still deeply in love. What a great bike.
I felt the need to remove that rear number-plate business. The new look gives me serious wood but .... I fitted some LED indicators and they flash a bit fast. Anybody know what resistor I could solder into the wiring to get the flash-rate back to normal?
Toolface is offline   Reply With Quote
Old 10-16-2005   #2 (permalink)
Favorite Bike: '01 Speed Triple
Yes. Two ten ohm resistors inline for each signal, front or rear. I soldered mine at the rear because I could hide them under the seat.
Speed3 is offline   Reply With Quote
Old 10-16-2005   #3 (permalink)
DEcosse's Avatar
Other Motorcycle: Suzuki TL1000S
First, they don't go "in line" they go across the lamp (parallel);
Second, don't use a resistor at all, (they will get hot so be careful where you mount them if you must use them!) get a non-load flasher module -
URL=http://www.usaled.com/store/item/opy8/EL98_Audible_LED_Flasher/EL98N_LED_BULB_FLASHER_8-_14_5_VDC_NON_BEEPER.html
or
http://www.superbrightleds.com/1157.htm (about half-way down the page)
I believe Autozone also carries a non-load flasher relay.
[ This message was edited by: DEcosse on 2005-10-16 14:52 ]
GSXR 1000 Front End Swap
Suzuki TL1000S................Suzuki SV650S.............Triumph Daytona
http://www.triumphrat.net/image.php?type=sigpic&userid=2434&dateline=1225242  733
Old 10-16-2005   #4 (permalink)
You're right, they go parallel. I just checked my drawing. The resistors get hot, but not enough to cause damage. I have the signal cancelling relay, but for those that don't, those are good links.
Old 10-16-2005   #5 (permalink)
DEcosse's Avatar
Just one additional piece of info - those 10 ohms need to be at least 20W rating. Anything less & they are going to fry.
Or a single 6 ohm resistor at 50W would do
Those are also available at the second link above - $20 for four resistors vs 1 relay @ $13 however - also plug n play vs the work of connecting them in kinda makes the relay option a no- brainer)
Old 10-17-2005   #6 (permalink)
Thank's DEcosse, I was wondering if I could use the 6 ohm 50w one.
[ This message was edited by: Speed3 on 2005-10-17 05:12 ]
Old 10-17-2005   #7 (permalink)
Lom
Speed 3, can you share some info on the signal cancelling relay? Does it cancel after turns as well (eg. like an OEM Yamaha) or just based on a timer? Brand, cost, source, etc.?Thanks!..
I'M IMMORTAL
well...so far.
http://www.triumphrat.net/albums/alb.../aad.thumb.jpg
Lom is offline   Reply With Quote
Old 10-17-2005   #8 (permalink)
Here you goClick
Old 10-22-2005   #9 (permalink)
Thanks, good advice. I found a flasher unit in the UK (£14) at Ultraleds.co.uk and I'm waiting for it to arrive. I am hoping that it will be a straight swap for the 3 spade flasher relay.
How do you wire rear indicators? Roary Club Cafe 4 02-12-2008 02:51 PM
Rear indicators too long ! freddytin Triumph SuperSports 4 03-30-2007 07:21 PM
Indicators sprinter900 RAT - United Kingdom 0 10-27-2006 09:10 PM
Thruxton rear fender removal and small indicators fitted robnobrakes Club Cafe 9 08-07-2006 02:58 PM
Rear Turn signal indicators (Flush mounts) rkx Sprint Forum 7 04-14-2004 09:15 PM
