SportbikeTrackGearMotorcycle.com Classifieds!BikeBanditShopTriumph.comRacerPartsWholesaleMotorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 10-15-2005   #1 (permalink)
helotrip
Hey all, I've got a little problem. About every third or fourth time I start up my '02 Triple the speedo(digital) doesn't work, it just sits on zero. I thought that maybe it had gotten wet or something, but I store it in a garage and everything. I tried unplugging and re-plugging in the instrument cluster and that didn't do the trick. Anyone had or heard of this problem? Thanks, Neil :???:
Old 10-15-2005   #2 (permalink)
Read here or if you have Tuneboy read here.
02S3 is offline   Reply With Quote
Old 10-19-2005   #3 (permalink)
If you found something that worked let us know. My speedo stopped working today.
Old 10-20-2005   #4 (permalink)
helotrip
I have tried turning the ignition on and off again, sometimes it works sometimes not. I'm going to try the battery terminal thing this weekend. I will let you know the results. Sorry to hear about your speedo, it's been a real pain for me.
Old 10-20-2005   #5 (permalink)
From reading the linked threads it looke like the ultimate fix is either a new tune or a reflashed ECU. I'm going to call my dealer today to see what they have to say about it.
[ This message was edited by: 02S3 on 2005-10-20 08:49 ]
Old 10-20-2005   #6 (permalink)
I'll have to try out the tuneboy kit to see if a reload will work since mine is doing the same thing. Like 3/4 of the time I start the bike up and the speedo reads 0 even when I get rolling. really a PITA.
Old 10-20-2005   #7 (permalink)
Yeah, this problem has been around the block a few times (check out the Sprint and Daytona forums as well), myself included.
Dealer re-flashed my ECU as well as tightening down a loose battery terminal connection. Problem hasn't come back.
dml955i is offline   Reply With Quote
Old 10-20-2005   #8 (permalink)
I've been living with this for more than a year. Typically if it doesn't work on the start I ride a block or two until I come to a stop sign, or light and do a shut down and restart. 8 times out of 10 it will then work.
I'll try cleaning the terminals and if that doesn't work I may get a new battery. If that doesn't work...a d*mn out-of-warranty trip to the dealer I guess.
Capt.
Captain_Rat is offline   Reply With Quote
Old 10-20-2005   #9 (permalink)
What my dealer told me was that the electronic sensor at the wheel is probably dirty and he said there should be 'a bolt down there you have to unscrew to release it'. Well, I looked all over the friggin place and didn't see a bolt or screw for me to mess with to get at the speedo sensor.
Old 10-20-2005   #10 (permalink)
Looking at the service manual, I think I'll just take the front wheel off myself and check the speedo drive.
Weird Speedometer problem StaggerLee Twins Technical Talk 18 08-29-2008 12:41 AM
Speedometer Problem Explained Speedo Issue BombFactory Triumph SuperSports 3 09-14-2007 11:00 AM
Speedometer/Odometer Problem? Silverado57 Twins Technical Talk 11 01-12-2007 07:56 AM
Speedometer problem oldyeller Modifications & Workshop Talk 6 12-21-2006 08:47 PM
Speedometer Problem britishbulldog Speed Triple Forum 1 04-26-2004 12:14 PM
