Actually, I believe that it is a 22mm hex and I managed to bodge the solution together for about $1. I went to the hardware store and found a nut that was about 22mm across, located a bolt to fit it, threaded the nut to the bolt and welded it together and voila! The nut fits perfectly into the hole, and the bolt end fits perfectly into a standard socket. I'm sure that you can find a 22mm hex somewhere, but I'll bet it's quite expensive (19mm is the largest "standard" sized hex). Besides, bodging is a lot more fun!
One day I got pulled over for speeding. The cop said, "don't you know the speed limit is 55 miles per hour?" I said, "yeah, I know...but I wasn't going to be out that long." - Steven Wright
