SportbikeTrackGearMotorcycle.com Classifieds!BikeBanditShopTriumph.comRacerPartsWholesaleMotorcycle.comTrident-Exhausts.comAdvanstarMotorcycleShows
ShopTriumph.com
Old 10-13-2005   #1 (permalink)
The owners' manual described a separate adjuster cover and adjusment clamp. There is in fact only one piece. I hope at least the torque spec is correct, and the (plastic) parts don't crack so I'm dragging my lights along the road in the dark.
2cats
How do you like my new avatar? It's the "Aprilia" badge on my side bag - the one that fell off and can't be replaced.
2cats is offline   Reply With Quote
Old 10-13-2005   #2 (permalink)
There are plastic parts on the 05 headlights?
Old 10-14-2005   #3 (permalink)
Favorite Bike: Speed3 -09
Martin_R's Avatar
Haven't noticed any plastics besides the instrument cluster when adjusting the lights on my '05. I think he has mistaken the black bulky thing that the lights and clocks bolt on to for plastic?
Martin_R is offline   Reply With Quote
Old 10-14-2005   #4 (permalink)
That's possible; I'll take a better look because I'm going to adjust again back up a little. It seemed awful light at the time, but I was busy holding the lamps up and trying to bolt the thing back on. It would be awfully unreasonable to make a part like that from plastic.
2cats
Old 10-14-2005   #5 (permalink)
If its like my 03 then you should have a metal bracket that holds the whole front headlight/fairing/guage assembly. All you should need to do is loosen one bolt on the underside of the neck that holds the headlights. Just adjust then crank it back down. I've never had a problem with stripping threads or anything with the front end.
Old 10-14-2005   #6 (permalink)
Martin_R's Avatar
It's the same. Loosen 1 bolt -> adjust -> tighten bolt back.
Old 10-15-2005   #7 (permalink)
The clamp that I ended up removing just fixed the headlamps - it did not hold the guage assembly (and I don't have a fairing). It exposed an extended pin on one piece, and a short groove in the other piece, which together serve to limit the range of adjustment.
Have people torqued to 15 Nm to their satisfaction?
2cats
Head Lamp Bucket Jhtjon Twins Technical Talk 19 06-11-2008 10:52 PM
Head lamp switch? CrazyCam Street Triple Forum 22 02-15-2008 01:29 PM
Head lamp (seems Dull) eternity Twins Technical Talk 5 09-27-2007 11:29 PM
Head Lamp Bulbs Mutley Tiger Mods & Bolt-Ons 33 12-11-2005 08:17 AM
Head Lamp Removal bcohen Twins Talk 7 12-04-2005 12:41 PM
