Old 03-30-2004   #1 (permalink)
I haven't picked up the bike yet, but was wondering if the fly screen is easy enough to remove to make it something I could put on for long trips and remove other times.
teacherkeith is offline   Reply With Quote
Old 03-31-2004   #2 (permalink)
It's pretty easy to remove. You just have to back out 4 screws and then replace the backing plate for the guage cluster.
Old 04-01-2004   #3 (permalink)
Cool, maybe I'll keep it then. Thanks.
Old 04-02-2004   #4 (permalink)
The only two problems I could see you having are:
1) Since the '04s come with the flyscreen attached, it won't have the original guage cluster backing on the pod. You might be able to find one from somebody with an '02 or '03 that has installed a fly screen.
2) I would worry that after a while of taking on/taking off, that the plastic threads would eventually get stripped.
Best advice would be to remove the fly screen as soon as you pick up the bike (if you really don't want it). You'll never miss it once you start riding and get used to the added wind blast...
dml955i is offline   Reply With Quote
Easy off/on mufflers ATGATT Twins Technical Talk 2 09-09-2007 08:29 PM
easy way to remove battery? parker2000 Sprint Forum 23 04-30-2007 08:58 AM
Dart Flyscreen (NB) vs National Cycle Flyscreen (Bella) dawgfan Twins Technical Talk 19 07-11-2006 11:22 AM
Easy Tailbob DaffyDuc Speed Triple Forum 0 10-29-2005 04:03 AM
Want to remove flyscreen?I have gauge cover. teacherkeith Speed Triple Forum 10 01-25-2005 11:40 PM
