Trident-Exhausts.comMotorcycle.comSportbikeTrackGearMotorcycle.com Classifieds!ShopTriumph.comRacerPartsWholesaleBikeBanditSpringfield Armory
RacerPartsWholesale
Old 10-10-2005   #1 (permalink)
englishvince
hi, can anyone help, i swapped my tt6 for a t509 this year, the 509 is a much better bike 2 ride, however as i like 2 drag race down santapod i find the japs kickin my arse, so i feel the need for more speed, so as this winters project i have just purchased a very crashed 04 955i for a small sum of £50 {not much left of it} but engine has only light damage, so what i need to know is... will the engine fit my 509 and if so what do i need to do? i have the injectors but will my pipes fit? are the wires the same? can i fit a power comander to it after as i cant fit one to the 509, and im still thinking about a turbo, will the engine take it or do u have to beef it up? i would be greatfull of any other go faster mods but cheep as poss as i am only a vinnie taking the japs on by me self!!!
Old 10-12-2005   #2 (permalink)
That's a pretty ambitious project. I'd be surprised if anyone else here has attempted it. Good luck and give 'em hell!
skeepee is offline   Reply With Quote
Old 10-12-2005   #3 (permalink)
I saw one on ebay I believe...it was in the UK...FI and all.
Chris: Dad, what\'s the blow-hole for?
Peter: I\'ll tell you what it\'s not for, son. And when I do, you\'ll understand why I can never go back to Sea World.
"Bloody hell. Believe that, and you'll believe we Brits aquired our empire to bring civili
AlucardIdraculA is offline   Reply With Quote
Old 10-14-2005   #4 (permalink)
I've looked into this and very carefully looked over one that's been done.
Basically you need the loom, ECU, airbox, clocks & tank, the water hoses also help.
the sensors are different so you can't use the earlier loom or ECU. and yes the engine will fit although the front mounts on top (cotton reel mount things) need cutting of to fit the later tank.
A lot of work and expence, I went the easier route, fitting a daytona lump (01) with the larger throttle bodies, changed the cams (02) and had the head skimmed down and gas flowed, took it to 140 bhp or so, I'm not great at the drag stuff but manage a couple of 10.4 quarters.
Cheers Mark.
rictus01 is offline   Reply With Quote
Old 10-14-2005   #5 (permalink)
Favorite Bike: 2001 Tiger
Other Motorcycle: 1998 Speed Triple
Did your '01 Daytona engine have the shim-over-bucket head and did you use your T509 ECU?
tyrebyter is offline   Reply With Quote
Swap your '02 or later Daytona 955i for '02 Sprint ST? ElTigre1 Daytona Deliberations 3 07-14-2007 12:33 AM
tiger1050 mirrors and 955i swap boocat Tiger Mods & Bolt-Ons 4 03-09-2007 03:02 PM
T509 Tail swap for '03 955i Punkinwing Speed Triple Forum 8 10-02-2006 04:19 PM
Swap, one S4 for one Daytona 955i doodledog RAT - United Kingdom 2 09-12-2006 06:23 AM
any interest in a 955i for S3 swap? 97TB Daytona Deliberations 0 06-12-2005 01:39 PM
