ShopTriumph.comSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comTrident-Exhausts.comSpringfield ArmoryBikeBanditRacerPartsWholesale
Old 10-08-2005   #1 (permalink)
Laurence
I just dropped my bike the other day and when I picked it up I noticed liquid dripping from the radiator. Must have knocked one of the hoses loose, I thought. But no,***** me, I discovered the front indicator is mounted on a sort of stud that goes into the radiator. So the indicator, being a sort of sticky-out-bit, makes contact with the tarmac before any of the other bits and that knocks it out of its mount on the radiator, and there you are with a little hole spurting out hot water, yes all right, I know, spurting hot water from the hole in the radiator, I mean!
Now, radiators don't come cheap. So a little bit of carelessness can mean it costs over 300 quid to replace your indicator.
Anybody else had the same problem?
You'd think the design blokes at Triumph could have thought of a better way of mounting the indicators. But there you are.
Anyone ever come across a way of taking the indicators off the radiator and mounting them somewhere else, where they won't cause so much damage if they get knocked off?
Old 10-08-2005   #2 (permalink)
Back in the days, some front indicators were mounted on the sides of the headlight bracket or on brackets attached to the handlebars.
Or you could just take 'em all off........... :wink:
Bob955i is offline   Reply With Quote
Old 10-08-2005   #3 (permalink)
Favorite Bike: '01 Speed Triple
Kellerman make bar end mounted signals that are pretty cool. A friend has them.
Speed3 is offline   Reply With Quote
Old 10-09-2005   #4 (permalink)
put some skyking sliders on and save all the fall over damage. aj
jabrady1234 is offline   Reply With Quote
Old 10-09-2005   #5 (permalink)
Where can one get those frame sliders? Wish a moderator made a 'sticky' with all these FAQ, rather than having to search to death issues we don't even know exist.
Thanks for the heads up buddy. And yes, that's a serious problem, since a simple tip-over can leave you stranded wherever you are; not good. Harley mounts them to the bars, but I think the frame-slider idea is the easiest and cheapest, plus it'd protect other bits in a harder fall.
JC
\'03 BMW K1200RS
\'03 SV1000 naked
ELP_JC is offline   Reply With Quote
Old 10-09-2005   #6 (permalink)
I have a set of the sky king frame sliders if you want them you could make me an offer. They have been installed but never "used". these mount to the front radiator bolt.
Agkistrodon is offline   Reply With Quote
Old 10-09-2005   #7 (permalink)
I just pmed you about the sliders !
SlvrSurfr is offline   Reply With Quote
Help me...before we lose him! Yandicoogina Speed Triple Forum 4 03-02-2007 09:32 AM
Now, it's 1984, knock knock on your front door...... JesusHoffa Biker Hang-Out 21 01-19-2007 09:57 PM
One item you don't want to lose! RedBird Twins Technical Talk 14 07-08-2006 01:26 PM
lose 15 lbs now,ask me how rodburner Club Cafe 9 06-02-2006 06:35 PM
Knock knock knocking... MikeRokkit Modifications & Workshop Talk 2 01-11-2006 11:02 AM
