BB,
Do you not have a new owners manual? It is in the specs and capacities section in the back... Easy to miss, but there. The proper torque for the drain plug and filter are there too. BTW, just make the filter as tight as you can by hand. Too much tighter can cause it to leak.
Isn't that Special...
